Cars & Trucks Logo
Posted on Nov 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gas gauge goes pass the full mark when
Gas gauge goes past the full mark when excelerating and bounces while driving but does not read properly.1995 Chevy Astro Van. When tanking up the needle goes past the full mark and seems to stay stuck even after burning 10 gallons of gasoline.
  • Anonymous Mar 31, 2014
    gas gauge wont move
Colin Stickland
Level 3:
  • Chevrolet Master 22,516 Answers
  • Posted on Nov 18, 2009
Colin Stickland
Chevrolet Master
Level 3:
Answers
22516
Questions
Helped
6999632
Points
66324
New sender unit required
2answers
Have a problem with gas gauge on a 2004 Chevy SSR
fuel gage sender unit-undefined-undefined-0.jpg You could use two resistors, Two different ohms specs for full and empty. Place resistor between proper wire colors in diagram. Turn on the key, If gage reacts properly to full and empty resistors, then I think the problem is the sending unit in gas tank. If not, the problem could be almost anywhere, wiring circuit--pcm--instrument cluster. I did see trouble codes relating to fuel gage sending unit. I hesitate to get into that? good luck
1995 yucon gas gauge reading iratically reading past full bouncing all over. now stays past full
Could be a short in the wiring, or a power problem.
You could unplug the harness at the tank to find out if it is a sending unit problem, but the truck won't run with the harness unplugged.
1helpful
Fuel Gauge wont move past 3/4 tank even with full tank
There is no easy fix.
Either the gauge on the dash is faulty, or the sending unit in the tank.
The sending unit uses a float which may be getting stuck at the 3/4 mark.
Gas gauge reads 3/4 when full and temp. won't come up past the cld mark. could this be a fuse issue?
Sounds like it could be an instrument cluster fuse or a possible ground issue. fuse would be easier. Did you have anything added recently such as a stereo or remote car start system?
Gas gauge jumps past full mark by 1/2 inch when key is turned on, then drops back and jiggles while in park, when you put it in drive the jiggling stops.
fuel level sensor it will eventually set a check eng light. the unit is on top of the fuel pump assembly it is a little black sensor that can be changed by itself or if u wish a new pump assembly will fix it also.
Doorlock won't unlock / Gas gauge stuck
Do the doors unlock when you shut the key off? Also unhook the purple wire to the sending unit in the tank, Gauge should read empty. Ground the purple wire, it should read past full. If it works this way, replace the sending unit in the tank.
Gas gauge
Sounds like you have a bare or broken wire earthing out on the chassis/body Trace the wires from the tank back to the engine bay and check that the wires are intact.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
