You need to contact the manufacturer of you drive, only they can reset the region counter on the drive for you, most programs that claim to do this, only make the problem worse, and might void your warranty :( Sorry
If you put in a multi-region DVD and it asks you to change region it will only change 5 times. The last region on the 5th try is what it stays as. You must download software to flash the unit and if done wrong will brick the unit.
You can't change the DVD coding. That part is how the DVD is recorded. However, your Mac will play DVDs from another region. It just typically defaults to one region. I have deleted the DVD player software (and preferences files) before and reloaded it to play DVDs from another region. If you plan to regularly play DVDs from multiple regions, you might want to look for special DVD software that will read DVDs from multiple regions.
Ask the people you purchased the bluray drive to give you instruction on how to reset (usually is about 5 times and then it gets stuck in the last region used, the Blu-ray region is set in the playback software, not the drive.). You may also want to try re-install the software, which resets it. Good luck.
well, un-install the dvd application software and install it again it will ask you the region and specify the correct on. you can also set the region on the setting tab.
the power dvd is the best application software for playing dvds, try it.
You can change the region code for your DVD player but not more than 4 times.
There are firnware updates to change DVDs to region free, if you are not carefull you can screw up your DVD drive.
Suggest you install a program to allow you to play any DVDs regardless of which region the DVDs were created for.
Go to www.dvdidle.com for their Region-Free program
you will have to go into the setup screen and find the region setting and change it to region 1. Note that you can only change the region about 5 times, and once you have changed it that many times you can't change it again. I usually recommend that people buy 2 DVD players if they need 2 regions, etc.
Hello, It would appear that the problem you are experiencing could be due to 1 of the 2 following items;
1. Re-install the software driver & software that came with the drive.
2. Set the region /Country that the drive will be working in or the language that you understand (USA=Region 1). It should be noted here that this option has a limitation of being changed up to 5 times but once it hits the fifth time the drive will be permanently set to that region and can not be changed anymore for the rest of the drives lifetime!!! The drive will usually work fine once it has been set (the default from the factory is ZERO (NOT SET)) and that may work fine for a while but it should be set to a region and it will understand all previously burnt /movie dvds that have this option set in the data already.
You can only change the region code a few times (usually 5), so I wouldn't do it. You should leave the current player at region 1, and buy and install another DVD player and set it to region 4, then you will have 1 for each region you want.
