SOURCE: Two cheap chronograph watches that won't set date and month
I would need the models on all watches to answer this question. I would make sure that the crown really doesn't pull out to a second position. They can be a little stubborn sometimes.
SOURCE: invicta model 4127, how to set day, date on the subdials
I don't have this model, but normally, invicta dates are set by pulling the crown out half-way and turning counter-clockwise.
SOURCE: how do i set the time on an Invicta Lupah mens
The Lupah has a chronograph so dont worry about the sub dials while your setting the time. Pull the crown out to the first position and set the time. For the date pull out to the second position and set the date.
To set the chronograph sweep arm pull the crown out and press and hold down the start button. The sweep arm will move into position. Stop it on the 12:00 or 0 position.
SOURCE: how do I change the date on my invicta divers
The answer to your specific question is the 2nd instruction below...I've also included two other settings:
Here are the 3 main crown positions
you need to know once you unscrew it from its locked down
position:
1) unscrewed, it can be manually wound, in one direction
[clockwise}...20 to 30 half-turns seems to be good to get it through
the night.
2) then, pulled out one small stop, the date can be advanced by turning the crown towards you (ie, counterclockwise)
3) pulled out one more stop, the time is adjusted by turning the crown.
I hope this helps!
SOURCE: Setting the date and time on watch
time:
hold left button -- hour will appear and begin flashing.
press right button to set.
press left button to advance to minutes, press right to set.
date:
press left -- date will appear. now hold left until day flashes.
press right to set.
press left to advance to month, right to set. then same again for year.
