Ryobi 2079r trimmer. shaft won't turn, clutch replaced 2-3 months ago, still in good condition
SOURCE: Ryobi TP30 straight shaft line trimmer convertible - drive shaft disconnected from motor
check both ends of shaft, they're usually a hex or torx head. sometimes the can strip or even snap off. if you find noticable damage replace the shaft
SOURCE: Replacing Drive Shaft for a Ryobi 725r
The lower flex shaft should cost around $40, unless you order it online and have to pay shipping. You should be able to get one from your local MTD dealer. (Ryobi is owned by MTD)
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from
the carburetor to the bottom of the tank. Leave enough slack in this
line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The
other
fuel line goes from the primer bulb to just inside the tank,
(about an inch). make sure that you get the right size fuel lines. The
plastic coupling goes on the end of this line, inside the tank. This
keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an
angle. They will feed much easier into the holes. You can than cut them
off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
SOURCE: Ref: Stihl FS46 string trimmer. Broken Flex shaft.
Remove orange sheild,remove single screw holding head in shaft then grab head with pliers and twist side to side until complete head is free.You should then be able to grab part of shaft.On power head loosen screws {about one turn each} that hold two white case halves near trigger,I think there are four,then there is a single torx screw on the bottom of lower case half in the middle that must be taken out to allow tube to be removed.Romove flexshaft from top.Check 4 plastic burnt to flexshaft,if there is you must replace tube liner as well,usally around bent part of tube the liner will go bad.
SOURCE: ryobi 2 cycle gas trimmer 705r/725r
The gas nipple that come out I have...whats goes in the other hole?
