Use itunes go to devices select your ipod and under the photos tab you will be able to select the pictures you want to delete. Hope this helps.
You should be able to, when you plug in your touch to your pc just click on your ipod an it has all the links at the top, one of those should be pics and you should be able to just click, sync pic with pc, or selected pics only, just click selected and unselect all the ones that you dont want
Step 1: plug in ur ipod with pc
step 2: open itunes
step 3: click on ur ipod on left tab on itunes
step 4: go to photos tab
step 5: mark the check button named "Sync photos"
step 6: select/unselect the folders
additional info: If you dont find the folder name you want to delete from ipod, NO PROBLEM, those folders will be deleted.
But BE SURE to click on the 'apply' button after checking/unchecking the folders.
SOURCE: how to delete photos from the photo albums in ipod touch?
well, im not completly sure, but some version of itunes automaticlly sinc the photos from your PC to the ipod. You can either delete the photos from your PC or go to the settings and un-check the picture sinc (on itunes). I use PC, so im not sure how that would work on Mac
SOURCE: delete photos off ipod touch 8GB?
I published a step by step solution that will allow you to do this, from within iTunes. This will work for you, and is easy to follow.
http://jawzblog.blogspot.com/2009/08/removing-photos-from-ipod-via-itunes_03.html
SOURCE: delete photos on V-Touch 8GB Video MP3
Deleting Files,Pictures,Videos,etc from MP3 Player
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Good Luck,
I hope this helps
Please rate me,
Thank You
SOURCE: How do i delete the Some of the photos from my
You could delete it with iTunes. Connect the iPod with the proper usb-cable and then go to your iPod in iTunes.. View the content of your iPod by clicking on it and the you can select it and delete it...
