Do you hear a clicking at the solinoid? grab the solinoid and turn it on to see if its getting voltage, you should feel it energize. you can turn off the water supply and disconnect the water line from the solinoid. there is a black pre screen inside the inlet if you have a tiny flat heat screwdriver insert it into the inlet and turn it out. clean it and retry. you can also make sure the orifice isnt clogged its located on the outlet side of the soliniod. when you remove you will probably have a stream of water come out of the feed tube thru the orifice, even if it has sat all summer. if water comes out you dont have a clogged orifice. donot try to **** out the orifice if its clogged you will need to get a new one fron www.aprilaire.com . you can verify it clogged by after cleaning the prescreen reconnect the water line inlet and turn on humidifier if water comes thru the solinoid with the outlet feed tube not connected then the orifice is clogged. If you clean the prescreen and the orifice is fine ,still no water then you will need a new solinoid you should also be able to purchase from aprilaire. here is links to the solinoid and orifice
http://estore.aprilaire.com/catalog/humidifiers/all-humidifier-parts/299
http://estore.aprilaire.com/catalog/humidifiers/all-humidifier-parts/267
hope this helps,
Mac
here is the owners manual go to page 12
http://www.aprilaire.com/themes/aa/en/ma...
Mac
