Cars & Trucks Logo
Posted on Nov 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to change a throttle position sensor on a 94 ford f150 5.0 4x4
ZJ Limited
Level 3:
  • Ford Master 17,989 Answers
  • Posted on Nov 05, 2009
ZJ Limited
Ford Master
Level 3:
Answers
17989
Questions
0
Helped
14459451
Points
60858
How to Replace a Throttle Position Sensor
(DIY & Save up to $135.75 ) - Time: 2.1 hours
Parts:
1. Throttle Position Sensor - $ 55.44
Tools:
1. Scan Tool
2. Screwdriver
3. Multimeter
Procedure:
1. Locate the OBD data link connector (DLC). Refer to your owner’s manual for the specific location.
  • Tip: The OBD-I data link connector is usually located in the engine compartment near the battery or the fuse box. The OBD-II connector (post 1995 cars) is usually located beneath the instument panel next to the steering column.
2. Turn your key to the“ON” position. Do not start the engine.
3. Plug your scan tool into the OBD data link connector. Turn on the scan tool and select the appropriate steps to read the diagnostic trouble code (DTC).
Scanner plugged into OBD-II data link connector.
  • Tip: The OBD-II diagnostic trouble code (DTC) is a 5 character alphanumeric code. The first digit is a letter that indicates the component group, the second digit is OBD mandated or manufacturer specfic, the third digit is a subgroup, and the fourth and fifth digits define the component and basic problem.
  • 4. Locate the throttle position sensor.
    • Throttle position sensor
    • 5. Disconnect the electrihow to change a throttle position sensor on a 94 - fc565b1.jpgor from the throttle position sensor.
    • Electrical connector removed
    6. Test the resistance of the throttle position sensor (TPS) with a digital multi-meter. If the resistance is out of specifications, the TPS must be replaced.
    • 7. Remove the throttle position sensor.
      Removing sensor mounting screws
      8. Install the new throttle position sensor. Tighten the mounting screws and attach the electrical connector.
    • 9. Erase the diagnostic trouble code (Dhow to change a throttle position sensor on a 94 - fde01cf.jpge scan tool using the“delete” or“erase” command. Road test your vehicle to see if the check engine light returns.
      Check engine light
    • Tip: If the check engine light returns, repeat the diagnostic process for additional DTCs or take your vehicle to a certified repair shop.
    Direct OE replacement
    Hope helped with this. Good luck (remember rated this help).
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
10193
Points
3 Related Answers
geo marin
  • 62 Answers
  • Posted on Aug 04, 2009
SOURCE: how to install throttle position sensor 94 buick
locate the throttle body and on the side match your new T.P.S sensor, its usually held on by 2 screws, torx kind, so you might have to buy that screw driver since it is not common. remove and disconnect the old one and install. if its adjustable you need to set it, with a voltmeter. if its not just make sure it engages and slides in fine.
fordexpert
  • 5692 Answers
  • Posted on May 16, 2010
SOURCE: how to change the Throttle positioning sensor TP...
This is a very easy part to change. It has 2 screws and 1 electric connector. One end of the TPS has an elongnated screwhole and the other screwhole is just a hole. At most you may need to use a pair of pliers on the screwdriver to grip the screwdriver better. The screws were put in to stay.
The back of the TPS has a slot which fits on the shaft of the Butterfly flap in the Airhorn. You just fit the slot over the shaft and then everything will be flush to the Airhorn Then tighten the screws, plug in the electric connector and usually you are done. If the idle speed does not seem as high or is higher than before that is what the elongnated screwhole is for. You would loosen both screws and twist the TPS to adjust. There is only slight adjustment possible.
Anonymous
  • Posted on Sep 30, 2010
SOURCE: 95 f250 7.3 is throttle position sensor on the pedal
i have a f350 ps and it starts and idles but i have no throttle nothing happens when i push the pedal and the check engine light comes on
My 94 Explorer with 4.0 engine won't idal when cold start up
Either your throttle position sensor or idle air control valve is shot try stepping on the gas while starting if the engine races then you can bring the rpms down then it stalls the throttle position sensor is N / G because the contact in the idle spot is worn out from regular use and the sensor needs to be replaced ///if you can't do this the idle air control valve is shot
1helpful
My 02 2.0L XLS Ford Escape is experiencing idle issues. Will not idle unless on the pedal, not consistent then . It is causing lunging in all 5speeds. High RPMs aren't troublesome.Thank you.
I had a similar problem with my ford contour. I replaced my throttle position sensor, that took care of the problem.
With car in ignition turned on, (car not running) check the voltage at the sensor. Should be 5 vdc. The two out side pins is where you check. If I remember the top pin is the positive and bottom is negative. Now you want to check feedback voltage. Put one probe to negative and the other to the middle pin. With throttle plate closed it should read around .5 volts (I've also seen people adust them to .94 volts). Check specs for your car. Now move throttle plate you should see the increase of voltage .5 to 5 volts max. Keep an eye on your meter to see if ther is any flats spots in the sensor. Meaning no voltage reading. Move to the open position slowly, you should see a steady increase of voltage no jumping around.if there is it needs to be replaced.
What does a throttle positioning censor for an 05 ford focus look like
I suggest you google 05 ford focus throttle positioning sensor. This sensor keeps you air intake throttle at the proper position when the engine is cold and changes position when the engine has warmed up. to locate the sensor, remove the hose that comes from the air filter housing to the engine. the hose you removed was connected to the air throttle. you can manipulate the position of this throttle by having someone push the gas pedal down slowly while you watch the throttle move. notice that the gas pedal cable is connected to the mechanism that opens and closes the air throttloe. also notice that beside this mechanism, you have an electric throttle positioning sensor. Pay close attention to the existing throttle positioning sensor before you remove it if you are planning on replacing this sensor. because if you do not install the new sensor in the same degree that the old one was in, you will throw the calibration off. word of advice. buy some throttle cleaner from your local auto parts. turn the car on with the air filter to throttle body hose off and have someone push the gas pedal down slightly to keep the engine from turning off. spray the throttle body cleaner til all the black crud comes off the inside of the throttle body. this dirty crud is what was making your throttle stick and not working properly.
My 94 Ford Crown Victoria cuts out when I give it some gas. It idles fine, but when I put my foot down on the gas pedal it does not what to go, it cuts out.
Test the TSP -throttle position sensor
on throttle body
May want to remember if your O2 Sensor is
over 100,000 miles & when you changed your
fuel filter ( 3 years,30,000 miles)
How old are the spark plugs, more than 4 years
or 60,000 miles
Test EGR Valve
1helpful
Changing throttle position sensor on a 2004
Removal & Installation
  1. Disconnect the negative battery cable.
  2. Disconnect the throttle position (TP) sensor electrical connector.
  3. Remove the screws and the TP sensor.
Throttle position (TP) sensor electrical connector
TP sensor
To install:
  1. Install the screws and the TP sensor. Tighten screws to 7 inch lbs. (3 Nm)
  2. Connect the throttle position (TP) sensor electrical connector.
  3. Connect the battery ground cable.
2answers
94 f250 ides to high already changed air control vave and can't find vaccum leak any suggestions?
check the PCV hose from the pcv valve to the rear of the intake manifold, real coomon to leak where the line hase a rubber end at manifold.
1helpful
Where is the trottle position senser located on my 1995 Ford F-250
The throttle position sensor is mounted on the throttle body.
Follow the big hoses from the air filter housing back to the engine and the first part on the engine you come to...... is the throttle body.
Buy the throttle position sensor first and match it to the part on the throttle body to identify the part you want to change.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
