Computers & Internet Logo
Posted on Nov 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you create fields - Computers & Internet
Threetech Solutions
Level 3:
  • Master 634 Answers
  • Posted on Nov 03, 2009
Threetech Solutions
Master
Level 3:
Answers
634
Questions
0
Helped
110164
Points
1539
There is 2 more different fields tell me which you want to create.
2answers
Creat a new blackberry id
    • Do one of the following: When you first set up your new BlackBerry smartphone, click Create a BlackBerry ID. ...
    • Complete the fields on the screen. The mandatory fields include a username (which is an email address), password, screen name, password recovery question, and password recovery answer.
    1. Create a BlackBerry ID using your smartphone - User Guide ...
  • BlackBerry Manuals Help
    How to invoke a ms.access using parser
    To parse a Text field that contains two words separated by a comma, follow these steps:
    1. Open any existing database.
    2. Create a table with the following structure: Table: Parse2Words
      Field Name: Empl
      Data Type: Text
    3. View the Parse2Words table in Datasheet view and type the following three records in the Empl field: Smith, John
      Callahan, Laura
      Fuller, Andrew
    4. Create the following query based on the Parse2Words table: Query: QueryTest
      Field: FirstName: Right$([Empl],Len([Empl])- InStr(1,[Empl],",")-1)
      Show: True
      Field: LastName: Left$([Empl],InStr(1,[Empl],",")-1)
      Show: True
      NOTE: You can modify the QueryTest query to account for spaces between the two parts in the Empl field. For example, if the text in the Empl field is "Smith,John" without spaces, remove the -1 from the FirstName field expression.
    5. Run the query. Note that the QueryTest query separates the text in the Empl field into the two fields below: FirstName LastName
      John Smith
      Laura Callahan
      Andrew Fuller
    1helpful
    A code to create a calculator in lotus notes . I have created the buttons and fields for each number, in two separate forms.I recall the values from the fields once we press the button using get field.I...
    You should have just one field for the calculation, call it "MyField", then each button should push it's value to that field. So
    ButtonValue := "1" ;@SetField( "MyField" ; MyField + ButtonValue )
    Where "ButtonValue" is the value of the button, so "+" or "8" or whatever.
    Pressing "=" should then compute the formula that has been made up in "MyField".
    That's a start for you.
    1helpful
    How to create yahoo id
    Hey welcome to fixya. I hope u 'll be fine.
    To make a yahoo ID just Click Here
    Fill all the fields carefully, and then last click on "Create my Account". It 'll create your account.
    if u feel help anywhere in filling the fields again, do tell me
    I hope your problem will be solved.
    If u think that it was helpful Then Please do rate me
    THANKS
    2answers
    I want to create a function in access to calculate a total. Where can I find a step by step guide?
    If you already have a field where you want the total to be if you right click on the field and go to properties and find out the name of the field and also the 2 or more other fields that you want to add or multiply together then you can make the total field equal to the formula ie
    if you have 3 fields
    Field one = value1
    Field two = value2
    Field total = total
    in design mode you would right click on the total field and go to properties and in the properties there should be a field where you can enter a formula.
    in there you would enter something along the lines of
    =value1.value + value2.value
    Then when you have it normal view ie you open it, it should always add the values together and put the sum of them into the total field.
    If you want an example database post back and I will create one.
    No available fields in form wizard
    If you select the correct table from the drop down, the fields should be shown in the box. or keep the table open and try creating form. or create a blank form and on the right side you will get tables and fields, you can just drag and drop required fields
    About visual basic coding
    The standard way of creating a database using VBA, which can be modified to suit your needs is this--> Note: the code (wspDefault.CreateDatabase("Newdb.mdb"...), can be altered to save the database in a folder  such as "C:\NEWDB\text.mdb". sub NewDatabase()     Dim wspDefault As Workspace, dbs As Database     Dim tdf As TableDef, fld1 As Field, fld2 As Field     Dim idx As Index, fldIndex As Field     Set wspDefault = DBEngine.Workspaces(0)     ' Create new, encrypted database.     Set dbs = wspDefault.CreateDatabase("Newdb.mdb", _         dbLangGeneral, dbEncrypt)     ' Create new table with two fields.     Set tdf = dbs.CreateTableDef("Contacts")     Set fld1 = tdf.CreateField("ContactID", dbLong)     fld1.Attributes = fld1.Attributes + dbAutoIncrField     Set fld2 = tdf.CreateField("ContactName", dbText, 50)     ' Append fields.     tdf.Fields.Append fld1     tdf.Fields.Append fld2     ' Create primary key index.     Set idx = tdf.CreateIndex("PrimaryKey")     Set fldIndex = idx.CreateField("ContactID", dbLong)     ' Append index fields.     idx.Fields.Append fldIndex     ' Set Primary property.     idx.Primary = True     ' Append index.     tdf.Indexes.Append idx     ' Append TableDef object.     dbs.TableDefs.Append tdf     dbs.TableDefs.Refresh     Set dbs = Nothing End Sub
    Hope this helps! Please let me know if you have any questions.Thank You,Raph30
    How to create program in delphi
    i wants to create form for data input
    with the condition
    18helpful
    3answers
    Using drop-down form field in a word 2007 template
    You need to protect the form (Protect Document, Editing Restrictions (Filling in Forms) then Start Enforcing Protection, the drop down menu will then work.
    Grand Canyon Tech
    Grand Canyon Tech
