1991 Nissan Pickup Logo
Posted on Nov 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clutch cable connected to pedal assembly broken or disconnected
Clutch cable connected to pedal assembly need drawings to see diagram of entire assembly
Anonymous
Level 2:
Novelist:
  • Expert 165 Answers
  • Posted on Nov 03, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
165
Questions
Helped
56705
Points
397
I have never seen a cable operated clutch on this model, only hydrolic, with a master cylinder and slave.
1helpful
Just bought a 1996 jeep Cherokee didnt get it a mile then a noise no clutch.the cable didnt break just the bracket that holds the cable to pedal.help please
Here's a link to one of many parts places, complete with a diagram you can use to identify and order the broken part. There are several components to the clutch pedal unit. Study this diagram and see if you can identify the broken piece. Then you can order it, and either take it to a trusted mechanic or do it yourself. Your local auto parts store can order as well.
PEDAL CLUTCH CHEROKEE Fits 1996 JEEP CHEROKEE
How to diconnect clutch cable "U"- shape clip that connects the cable to the pedal-1989mazda323 1.6L
Loosen the adjuster assemble this makes the inner cable longer then is will come off
Broken clitch cable on 2000 chevy impala...how do u replace it..the wires are broken
see this steps and fix it. God bless you
Clutch Cable Replacement The clutch cable provides a means to "break the drive" between the engine and the wheels. The engine spins constantly, but the wheels do not, so in order to stop a car's wheels without turning off the engine, the wheels have to disconnect from the engine. When the clutch pedal is pressed, the cable disengages the plates, allowing the driver to shift gears or coast without killing the engine.
A failing clutch cable may make the clutch pedal difficult to depress. If the clutch cable fails, the clutch pedal may remain on the floor and not return to its normal position.
To replace the clutch cable, disconnect it from the clutch pedal (usually inside the vehicle) and from the release mechanism or cable attachment that operates the clutch assembly (usually at the transmission beneath the vehicle). A new clutch cable is then installed and adjusted. (The specifics vary according to the vehicle and range from straightforward to very difficult.)
Car will not start, car runs when the starter is bumped over. how do I check the clutch switch?
the clutch switch is on the pedal assembly above the clutch pedal disconnect the two wires and joint them with a fuse 20A o 30A with ebrake on and trans i neutral start the car no need to press clutch pedal this time, if start replace the switch, if not check the starter cable or the starter itself, the ignition switch.
2helpful
2answers
How to adjust clutch pedal on 86 mustang lx
clutch is supposed to be self adjusting. Here are instructions for replacing the adjuster:
REMOVAL & INSTALLATION
See Figure 1
  1. Disconnect the battery cable from the negative terminal of the battery.
  2. Remove the steering wheel using a steering wheel puller, Tool T67L-3600-A or equivalent.
  3. Remove the lower dash panel section to the left of the steering column.
  4. Remove the shrouds from the steering column.
  5. Disconnect the brake lamp switch and the master cylinder pushrod from the brake pedal.
  6. Rotate the clutch quadrant forward and unhook the clutch cable from the quadrant. Allow the quadrant to slowly swing rearward.
  7. Remove the bolt holding the brake pedal support bracket lateral brace to the left side of the vehicle.
  8. Disconnect all electrical connectors from the steering column.
  9. Remove the 4 nuts that hold the steering column to the brake pedal support bracket and lower the steering column to the floor.
  10. Remove the 4 booster nuts that hold the brake pedal support bracket to the dash panel.
  11. Remove the bolt that holds the brake pedal support bracket to the underside of the instrument panel, and remove the brake pedal support bracket assembly from the vehicle.
  12. Remove the clutch pedal shaft nut and the clutch pedal, as outlined above.
  13. Slide the self-adjusting mechanism out of the brake pedal support bracket.
  14. Examine the self-adjusting mechanism shaft bushings on either side of the brake pedal support bracket, and replace if worn.
To install:
  1. Lubricate the self-adjusting mechanism shaft with motor oil and install the mechanism into the brake pedal support bracket.
  2. Position the quadrant towards the top of the vehicle. Align the flats on the shaft with the flats in the clutch pedal assembly, and install the retaining nuts. Tighten to 32-50 ft. lbs. (43-67 Nm).
  3. Position the brake pedal support bracket assembly beneath the instrument panel, aligning the four holes with the studs in the dash panel. Install the four nuts loosely.
  4. Install the bolt through the support bracket and into the instrument panel. Tighten to 13-25 ft. lbs. (18-34 Nm).
  5. Tighten the four booster nuts that hold the brake pedal support bracket to the dash panel to 13-25 ft. lbs. (18-34 Nm).
  6. Connect the brake lamp switch and the master cylinder pushrod to the brake pedal.
  7. Attach the clutch cable to the quadrant.
  8. Position the steering column onto the four studs in the support bracket and start the four nuts.
  9. Connect the steering column electrical connectors.
  10. Install the steering column shrouds.
  11. Install the brake pedal support lateral brace.
  12. Tighten the steering column attaching nuts to 20-37 ft. lbs. (27-50 Nm).
  13. Install the lower dash panel section.
  14. Install the steering wheel.
  15. Connect the battery cable to the negative terminal on the battery.
  16. Check the steering column for proper operation.
  17. Depress the clutch pedal several times to adjust the cable.
2helpful
Have problems with changeing clutch cable vw golf 3. Can not remove old cable from pedal.
Disconnect the cable at the transmission side first then you can remove the cable stay at the pedal assembly. If you have an automatic clutch tensioner, step on the pedal first then attach two securing wings on the cable boot housing to lock up the cable from the lever.
2answers
Clutch pedel stuck on floor
The clutch master has blown out
Need diagram of routing for the clutch cable
check connection at or right before clutch connection point
Info on do it tyour self clutch removal on 2001 mustang 3.8
REMOVAL:
  1. Lift clutch pedal to uppermost position to disengage clutch and brake pedal pivot shaft.
  2. Push clutch and brake pedal pivot shaft forward and unhook clutch release lever cable from clutch and brake pedal pivot shaft and allow it to slowly swing rearward.
  3. Raise and support vehicle.
  4. Remove clutch release lever dust shield.
  5. Disconnect clutch release lever cable from clutch release shaft.
  6. Remove retaining clip, then clutch release lever cable from flywheel housing.
  7. Remove starter motor from flywheel housing, then engine rear plate to front lower flywheel housing bolts.
  8. Remove transmission.
  9. Remove flywheel housing back just far enough to clear clutch pressure plate, then remove housing.
  10. Remove clutch release shaft from flywheel housing by pulling it through window in flywheel housing until retainer spring disengages from pivot.
  11. Remove clutch release hub and bearing from clutch release shaft.
  12. Loosen six clutch pressure plate bolts evenly to release spring tension gradually and avoid distorting clutch pressure plate. If same clutch pressure plate is to be installed, mark plate and flywheel so pressure plate can be installed in its original position.
  13. Remove clutch pressure plate and clutch disc from flywheel.
INSTALLATION:
  1. Position clutch disc and pressure plate assembly on flywheel, noting following:
    1. Three flywheel housing to block dowels on flywheel must be properly aligned with clutch pressure plate.
    2. Bent, damaged or missing flywheel housing to block dowels must be replaced.
    3. tart clutch pressure plate bolts but do not tighten.
    4. Avoid touching clutch disc face, dropping parts or contaminating parts with oil or grease.
    5. Align clutch disc using suitable alignment tool inserted in pilot bearing.
    6. To avoid clutch pressure plate distortion, alternately tighten bolts a few turns at a time, until they are all tight, then tighten to specifications.
  2. Install transmission to flywheel housing.
  3. Install engine rear plate to flywheel front lower housing bolts, then connect clutch release cable to flywheel housing and connect retaining clip.
  4. Connect clutch release lever cable to clutch release shaft, then install clutch release lever dust shield.
  5. Install starter motor.
  6. Lower vehicle, then install clutch release lever cable as follows:
    1. Lift clutch pedal to disengage clutch and brake pedal pivot shaft.
    2. Push clutch and brake pedal pivot shaft forward and hook end of clutch release lever cable over rear of clutch and brake pedal pivot shaft.
  7. Cycle clutch pedal several times to adjust clutch release lever cable
I need to tear down my transmission in a 1988 Chevrolet Cavalier Z24 2.8L i am fixing the clutch and i need diagrams on how to take it apart and put it back together
Below is process for removing and replacing the clutch assembly.
Hope this helps, good luck.
Regards,
See Figures 1, 2 and 3
0900c1528003be16.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: Exploded view of the clutch disc and cover assembly
  1. Disconnect the negative battery cable.
  2. If equipped with a cable clutch (1982-84 vehicles), disconnect the cable at the clutch release lever and transaxle, as outlined earlier in this section.
  3. For 1985-94 vehicles remove the sound insulator from inside the vehicle. Disconnect the clutch master cylinder pushrod from the clutch pedal.
0900c1528003be17.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: Disconnect the clutch actuator (slave) cylinder line - 1995-96 vehicles
  1. Remove the transaxle, as outlined earlier in this section.
  2. Mark the pressure plate assembly and the flywheel so that they can be assembled in the same position. They were balanced as an assembly at the factory.
  3. Loosen the attaching bolts one turn at a time until spring tension is relieved.
  4. Support the pressure plate and remove the bolts. Remove the pressure plate and clutch disc. Do not disassemble the pressure plate assembly; replace it if defective.
  5. Inspect the flywheel, clutch disc, pressure plate, throwout bearing and the clutch fork and pivot shaft assembly for wear. Replace the parts as required. If the flywheel shows any signs of overheating, or if it is badly grooved or scored, it should be refaced or replaced.
0900c1528003be18.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 3: You must follow the specified sequence when tightening the pressure plate retaining bolts
To install:
  1. Clean the pressure plate and flywheel mating surfaces thoroughly.
  2. Position the clutch disc and pressure plate into the installed position, and support with a dummy shaft or clutch aligning tool, tool J 29074 or equivalent. The clutch plate is assembled with the damper springs offset toward the transaxle. One side of the factory supplied clutch disc is stamped "Flywheel Side".
  3. Install the pressure plate-to-flywheel bolts. Tighten them in the sequence shown in the accompanying figure, as follows:
    1. Tighten bolts 1,2,3, then 4,5,6 in the sequence shown to 12 ft. lbs. (16 Nm).
    2. Tighten bolts 1,2,3, then 4,5,6 in the sequence shown to 15-22 ft. lbs. (22-30 Nm) plus an additional 30° turn.
    3. Remove the clutch alignment tool.
  4. Lubricate the outside groove and the inside recess of the release bearing with high temperature grease. Wipe off any excess. Install the release bearing.
  5. Install the transaxle, as outlined earlier in this section.
WARNING When adjusting the cruise control switch, do NOT exert an upward force on the clutch pedal pad of more than 20 lbs. (89 N) or damage to the master cylinder pushrod retaining ring may result.
  1. For 1985-94 vehicles, attach the clutch master cylinder pushrod to the clutch pedal and secure with the retaining clip. If equipped with cruise control, check the switch adjustment at the clutch pedal bracket. Install the sound insulator.
  2. If equipped with a cable clutch, attach the clutch cable at the transaxle and clutch release lever. Check the clutch operation by lifting the clutch pedal up to allow the mechanism to adjust the cable length. Depress the pedal slowly a few times to set the pawl into mesh with the quandrant teeth.
ADJUSTMENTS
All 1982-84 models have a self-adjusting clutch mechanism located on the clutch pedal, eliminating the need for periodic free play adjustments. The self-adjusting mechanism should be inspected periodically as follows:
  1. Depress the clutch pedal and look for the pawl on the self-adjusting mechanism to firmly engage the teeth on the ratchet.
  2. Release the clutch. The pawl should be lifted off of the teeth by the metal stop on the bracket.
On 1985 and later models, the hydraulic clutch system provides automatic clutch adjustment. No adjustment of clutch linkage or pedal position is required.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
