Dryers Logo
Posted on Nov 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Whirlpool Gold Dryer, it stoped running, there is power to the Cotrol panel and I can select which cycle to use. Whenever I press the start button I hear a realy clicking but the unit does not start. What may be the probelem: heating element, fuse, control panel, .... Please help Thanks Jane
Anonymous
Level 3:
President:
  • Whirlpool Master 1,922 Answers
  • Posted on Nov 05, 2009
Anonymous
Whirlpool Master
Level 3:
President:
Answers
1922
Questions
Helped
617643
Points
4631
Motor start cap,motor start windings,control panel thermistor open
All else appears to be working except the dryness level selection button does not light up and will not allow selection
How do I read the digital display panel and controls on my ...
www.samsung.com/uk/support/skp/faq/1025253
Samsung ElectronicsAug 12, 2014 - The Drying light will illuminate and remain lit until the cycle is ... the indicators will light up until you press the Start/Pause button. ... When you turn on your dryer the Cotton Cupboard Dry cycle is selected by default. ... Drying Level button ... If you do not turn the Drum Light off within 5 minutes of turning it on it ...
Dryer Control Panel And Functions - Samsung
www.samsung.com/ca/support/skp/faq/230147
Samsung ElectronicsJan 7, 2015 - To set Dry Level in the Normal, Heavy Duty, or other Sensor Dry ... An indicator light illuminates next to the selection. ... Temp Selection Button ... When using Manual Dry, you can select the drying time by pressing the Time Selection Button. Important: Clothes may not dry completely if the drying time is not ...
MACHINE OPERATION
docs.whirlpool.eu/_doc/501930002795EN.pdf
Material thickness: whenever there is greater load than the dryer can handle, ... Do nottumble dry: nylon stockings, delicate embroidery, fabrics with metallic ... The indicator lamp above the relevant button lights up to confirm your selection. ... Wait at least 5 minutes, to allow the laundry to cool down, before you unload the ...
501930001546EN.pdfDOWNLOAD
Jan 01, 2016 • Dryers
The panel has power, I can select the cycle, but when I press the start button nothing happens. I hear a click and nothing occurs. I've been told it could be the thermostat, cut-off or element. I cant...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Whirlpool dryer LGQ7030KQ1 won't run the dryer won't run when the start button is pressed. Later we had it in the off position and the 30 minute wrinkle cycle was set to on. Suddenly it began to run. So...
Hello there, I would try removing the control panel and check for broken wires in which mice we'll get in there and chew them. This is what happened to me.
Aug 02, 2017 • Dryers
Error code pf
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
1helpful
Dryer won't run unless I put pressure on the cycle control knob after pressing Start
sounds like you need to replace your timer, or either unplug the machine, an open the head panel an see if any wires are loose in there, changing the timer is an easy job, you should have no problems doing it ......good luck!
When I press the start button, the dryer does not run
Is this a colipso dryer, I think that is how you spell it? If so then yes it very well could be a control board.
2answers
Dryer stops working after 2 minutes into cycle
If it is new, is it not under warranty?
does it run ok on air dry? Is there good air flow?
post your answers in comments
Kenmore dishwasher stops midway through
http://fixitnow.com/wp/2006/03/29/whirlpool-kitchenaid-kenmore-dishwasher-poor-cleaning/
Here is a good page that can help you resolve this issue and buy the parts needed
I HAVE A WHIRLPOOL DRYER. TURN THE TIMER SELECT ON. THEN TURN START KNOB TO ON, THEN PRESS THE SAME KNOB IN TO START CYCLE. YOU CAN HERE THE TIMER AND SOUNDS LIKE THE CONTACT IS WORKING, BUT CYCLE WON'T...
Hello dacarle,
Welcome,
You said, I HAVE A WHIRLPOOL DRYER. TURN THE TIMER SELECT ON. THEN TURN START KNOB TO ON, THEN PRESS THE SAME KNOB IN TO START CYCLE. YOU CAN HERE THE TIMER AND SOUNDS LIKE THE CONTACT IS WORKING, BUT CYCLE WON'T START.
Please send me the model number so i can check out the problem.
Waiting your response
Huuum
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
