2002 Jeep Grand Cherokee Logo
Posted on Oct 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need instructions on how to replace power window motor for the front driver side window of a 2002 Grand Cherokee
Anonymous
Level 3:
President:
  • Master 353 Answers
  • Posted on Oct 30, 2009
Anonymous
Master
Level 3:
President:
Answers
353
Questions
Helped
351293
Points
1581
Power Window Motor: Service and Repair
REMOVAL
1. Disconnect and isolate the battery negative cable.
2. Remove the window regulator from the door.
3. Place the window regulator on a suitable work surface and remove the screws that secure the power window motor to the window regulator.
4. Remove the power window motor from the window regulator.
INSTALLATION
1. Position the power window motor onto the window regulator.
2. Install and tighten the screws that secure the power window motor to the window regulator. Tighten the screws to 9 Nm (80 in. lbs.).
3. Install the window regulator onto the door.
4. Reconnect the battery negative cable.
2answers
Window on right side dont work on 2002 jeep grand cherokee
if its electric a fuse could be bad or a shortage in the wiring
2answers
I need to replace the rear driver's side window lift motor. Where can I find the instructions? Thanks.
All the information that you need can find it in ZJ-Secc-8S-Power-Windows
I really hope help with this (remember comment and rated this).
Blower not working on 2002 jeep grand cherokee, Need electrical schematic.
check the wires going to the blower motor for power on both sides if you get power on both sides of blower motor the problem is a bad blower motor resistor if you got power coming in on one side only you have a bad blower motor.
2002 G. Cherokee. Jeater blower no longer works.
check blower motor located under hood in front of winshield drivers side or passenger side floor feet compartment can't miss round black two wires and small pipe hose on side,john
Replacement Front, Driver Side Window Regulator
first these are easy to do,second look on ebay a-1 auto I think sells replacement for around $100 U.S
Take door panel off,there are several bolts in reg and 2 keepers on the window glass unhook the 2 keepers unplug the motor and turn unit and bring out the bottom of the doorthe window glass does NOT have to come out. it should only take less than an hour to do.
3answers
Pontiac grand prix --- need pix on auto window replacement
THE CABLES ARE BROKEN ON THE WINDOW REGURALTORS, THE NUTS THAT SECURE THE WINDOW AND RAGURLATOR ARE 10MM
2002 Grand Am Power Window Problem
before you replace the mtr try having the switch looked at , start with the basic first replacing the mtr is not a cheap fix good luck kdc744
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
