As far as I can remember, the Jetta has a ball & socket linkage on top of the gearbox. This linkage eventually wear out & the ball will pop out of the socket thus giving you no clutch pedal.
Lift the bonnet & have a look on the right hand side of the engine, you should be able to see what I mean. Push the ball back into the socket & you'll get your clutch pedal back. Chances are the clutch will probably go again unless you replace the worn parts but they're a cheap enough fix.
Hope this helps, Stephen.
I am having the same issue with my 1996 vw jetta gl 2.0l, one evening the clutch just slammed to the floor while i was trying to shift and i no longer had a clutch. Can you explain a little more in detail about this ball thing on the right side of the motor, and would that be the transmission side?
I also believe there is no master cylinder on these cars. And has no relationship with the brakes. Its all cable self adjusting clutch
Clutch master cylinder is shot.
There is no master cylinder on mine
