Computers & Internet Logo
Posted on Oct 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i turn on my computer, it says on the monitor, veryfying dmi pool data, it doesn't do anything else, its been like that for about 1/2 hour
Anonymous
Level 2:
  • Expert 69 Answers
  • Posted on Oct 25, 2009
Anonymous
Expert
Level 2:
Answers
69
Questions
0
Helped
18181
Points
220
Try the following link. This must help.
http://www.duxcw.com/faq/computer/dmi.html
regards
Sandeep
When i boot the computer it says verifing dmi pool
Hello there and welcome to fixya
A. DMI or DesktopManagement Interface (pdf) is a layer of abstraction between system components and the software that manages them. The System Management BIOS (SMBIOS) is an extension of the Basic Input Output System (BIOS) that formulates and delivers this information to the operating system. The pool data is the information. In short, when the BIOS is "Verifying DMI pool data" it is verifying the table of data it sends to the operating system (Windows, etc.). If it isn't sucessful, it should return an error. Wait a reasonable period of time for it to finish. It may make take some time or it may be stuck. Possible fixes:
1. If you changed the hardware just before this problem occurred (e.g., installed a new hard disk drive), unchange it.
2. If you installed a new hard disk drive, set the motherboard CMOS Setup to Auto for the drive type. You may have to disconnect the drive first.
3. Enable "Reset Configuration Data" (may be "Force Update ESCD" in some CMOS Setuups) in the motherboard CMOS Setup PNP/PCI configuration. (Rebooting will automatically disabled it after it has done its thing.)
Restore disks didn't find ghostdriver
DMI pool data is a normal boot process if it never boots past this then there is usually a driver or new hardware conflict.....if you have installed any new hardware remove it and try to boot again
2answers
Possible main memory fault; swap memory modules if you have more than one installed. Otherwise, clear the CMOS contents in the Bios and re-configure. ( remove the coin battery and short circuit the battery socket contacts then re-install the battery )
Wont start up grey screen with warning verifying dmi pool data on my desktop pc which is acer aspire
well varifying DMI pool data is not a warning its a process where your system hangs. install new windows or repair the old one.
2helpful
7helpful
5answers
This Acer AST 160 I'm working on crashed...
Computer stops at verifying dmi pool data. Issue: Computer stops at verifying dmi pool data.
Cause: This issue can be caused by any of the below reasons.
  1. Corrupt boot files on the computer.
  2. Settings for hard disk drive are not correct.
  3. Floppy diskette or CD in computer causing issue.
  4. Boot devices not set properly.
  5. BIOS corrupt or misc. setting not set properly.
  6. Connections loose or disconnected.
  7. Bad Hard disk drive or other bad hardware.
Solution: Corrupt boot files on the computer
If the computer has no bootable files on the drive it is attempting to boot from it is possible that the computer may halt at " verifying dmi pool data..."
To resolve this issue:
  • Boot from a bootable floppy diskette. Ensure that this diskette was made on the same Microsoft Windows operating system that is installed on your computer.
  • Once at the A:> prompt type "sys c:" and press enter. This should report the message "File system transferred." Once transferred remove the diskette and reboot the computer.
If the computer continues to not boot attempt to re-create the master boot record by booting from the bootable floppy diskette again. Once at the A:> prompt type "fdisk /mbr" and press enter. This should return you to the prompt without giving you any message. Once at the prompt remove the diskette and reboot the computer.
Additional information about the "fdisk /mbr" command can be found on document CH000175.
Note: The above information only applies to Microsoft Windows users. If you are running a Linux / Unix variant or other operating system such as OS/2 and the computer is freezing at this DMI message ensure that Linux / Unix has been properly installed first and/or your boot manger is not corrupt.
The computer freezing at "Verifying dmi pool data..." may be caused when the hard disk drive settings within CMOS are not set properly. Enter CMOS and verify that the hard disk drive settings are set properly and/or that it is set to Auto Detect. Additional information about entering CMOS setup is found on document CH000192.
Verify no floppy diskette or CD is in the computer. In some cases the computer may be trying to boot from either of these drives causing issues with the boot sequence.
The computer stopping at " verifying dmi pool data..." can be caused when the boot devices on your computer are not set properly in CMOS. First, verify that no CD or diskette is in your computer. If a CD or diskette is in the computer attempt to remove this first to determine if it was attempting to boot from it.
If No CD or diskette is in the computer and your computer still halts at the DMI message enter CMOS setup (steps found on document CH000192) and verify that the boot options are set properly. We commonly recommend that the floppy be set the first boot device, hard drive as the second boot device and the CD-ROM as the third boot device.
If none of the above recommendations have resolved your issue
2answers
My Zenith PC displays Verifying DMI pool data . Update Success
Sometimes this can be even simpler. Put in your Windows CD and boot to safe mode command prompt and type fixmbr. This will repair your master boot record for your primary boot harddisk. Eject the windows CD and reboot and see if it fixes your problem.
1helpful
Startup does not complete
plz check the website http://www.duxcw.com/faq/computer/dmi.html
Computer says something about verifying pool data
If it says something along the lines of verifying dmi pool data then you might have a problem with your BIOS ( the setup utility you refer to ). Here is a URL that describes a solution to this problem, it is pretty intense if you don't have at least above average computer skills - http://www.duxcw.com/faq/computer/dmi.html. Let me know if you need any further assistance with this.
Serge C.
Frezes at verifying DMI settings. Already changed MB and Power supply. Lan connection only flashes green once in a while should be constant. Tried on a working terminal and does the same.
The Desktop Management Interface (DMI) is a new
method of managing computers in an enterprise. The
main component of DMI is the Management Information
Format Database, or MIFD (the DMI Pool Data). This
database contains all the information about the
computing system and its components.
At times, some systems may experience hang
conditions after partitioning, formatting and initial
bootup of a hard drive. The message, "Verifying DMI
Pool Data" appears and the system hangs. This
condition may continue after the drive has been
removed.
! WARNING ! ALL SUGGESTIONS LISTED IN THIS
INFORMATION BULLETIN ARE BIOS RELATED. FOR
A PERMANENT SOLUTION, MAXTOR RECOMMENDS
THAT USERS CONSULT THEIR SYSTEM OR
MOTHERBOARD MANUFACTURER FOR BIOS
UPGRADES.
Suggestions to Resolve the Condition:
1.Apply power to the computer.
2.Access the system BIOS.
Set the drive type as None or Not Installed.
Load BIOS Defaults
Load SETUP Defaults
3.Save the BIOS changes and reboot the PC to a
System Boot Diskette.
4.Shut down the PC after the memory count is
displayed.
5.Reconnect the power and interface cables to the
hard drive.
6.Access the System BIOS.
7.Auto-Detect the hard drive. Ensure that the LBA
Mode option is enabled.
8.Save the BIOS changes and boot the PC with a
System Diskette.
9.Partition and format the hard drive via the
operating system.
10.Reboot the system. On bootup, the screen should
read:
Verifying DMI Pool Data
Update Successful
The system should continue booting normally.
Other Possible Solutions:
2.Access the System BIOS.
3.Disable both the Internal and External CPU Cache.
These features are located in either the "BIOS
Features" or "Advanced Settings" options of the
BIOS Setup.
NOTE: Consult the System or Motherboard User's
Manual for exact location of the Internal and
External CPU Cache settings.
4.Save the BIOS changes and reboot the PC to a
System Boot Diskette. On bootup, the screen
should read:
Update Successful
5.After the system successfully boots, re-start the
PC and access the system BIOS.
6.Enable the External CPU Cache. This feature is
located in the "BIOS Features" or "Advanced
Settings".
Manual for exact location of the External CPU
Cache setting.
! WARNING ! User's MUST re-enable this feature
for optimal system performance.
7.Save the BIOS changes and reboot the PC to a
should read:
Update Successful
NOTE: If the aforementioned suggestions fail to
resolve the issue, contact the system or motherboard
manufacturer to:
Remove the "Clear CMOS" Jumper and reset the
system BIOS
Obtain a Flash BIOS Upgrade
from pc help;
SYSTEM HANGS AT MESSAGE: "VERIFYING DMA POOL DATA":
You did not say what operating system you are running but I assume Windows 95 or 98. It is possible some Windows
system files are corrupted or perhaps the system doesn't like your ram (if you added or installed ram recently). There
is also a possibility that there is something wrong with your BIOS and you *may* have to update it, but I would avoid
doing that if at all possible.
A quick fix - if the problem is software related - is to:
1. boot to a Windows startup disk (one that matches your operating system). this step assumes that your PC is setup
to boot to the A: drive before the C: drive (via the BIOS SETUP program). If you don't have a Windows startup disk,
you will have to make one on another person's computer that has the same version of Windows. You make one via:
my_computer/control_panel/add_remove_programs/startup_disk
2. run "scandisk c:" to make sure that any file corruption is fixed before going to next step
3. do a "sys c:" from the "a:" prompt to transfer a good copy of Windows system files to c: drive
4. remove the boot floppy, reboot the system and see if all is well.
If that does not solve the problem you may have to reinstall Windows 95/98. Ouch!
I recently had someone bring me a computer that had this DMI error message problem and I tried the "sys c:" method
(with the startup disk) without success and had to entirely reinstall windows 95 (and almost all applications except for
some programs that did not need to be placed in any Program Files directory or other special location) to cure the
problem. However nasty a job that is, it did cure the problem.
Grand Canyon Tech
Grand Canyon Tech
