Computers & Internet Logo
Posted on Oct 24, 2009
I have connected my belkin to my computer, all the blue lights are lit, except the internet connection, I use AOL how can I get a connection ?
Anonymous
Level 1:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Contributor 169 Answers
  • Posted on Oct 25, 2009
Anonymous
Contributor
Level 1:
Mentor:
Answers
169
Questions
Helped
42769
Points
14
Hi
first try to power cycle the complete system that means unplugging all the cable and restarting the computer and router and then check that it is working or not if it doesnot work then try to connect directly to the modem ..if it connects then their is a problem in the router and router needs reconfiguration if it doesnot connect then you need to call aol and ask help with the isp troubleshooting .
if you get any problem in doing so you can get back to me on fixya
thanks
techbuddies
tip
How to Configure Belkin routers for Centurylink, Embarq, Bell sympatico, Bell...
How to Configure Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs ?
Configuring Belkin routers without installation CD for Centurylink, Embarq, Bell sympatico, Bell Canada ISPs :
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Do not connect the modem to the router.
  • Open internet explorer / Firefox / chrome or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router i.e., 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
Wired Part Configuration:
We need to configure the wired part by following these steps.
Step 1: You need to LOGIN to the router for making any changes. (No login password, just leave it blank and click SUBMIT)
Step 2: Click on LAN settings (found on left side of RSP), change the IP address from 192.168.2.1 to 192.168.40.1 and save changes.
Step 3: Now Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using another Ethernet cable.
***Once you are done that, you need to re-login to RSP by typing the new IP address 192.168.40.1 in the address bar of web browser.
Step 4: Check for the internet status at the top right hand corner of RSP. If it is connected then the wired part is working perfect with the router (wired computers will go online). Need not follow the steps below, directly jump to wireless part configuration.
Step 5: If the Internet Status is not connected then, click on CONNECTION TYPE (found on left side of RSP), it has to be selected as DYNAMIC and click next. It will ask for HOST NAME, leave it blank or you can type anything there and click on APPLY CHANGES.
Step 6: Now check for the internet status at the top right hand corner of belkin RSP. If it says connected then everything for the wired part is configured perfectly. You can go ahead and configure for the wireless part.
If it is not connected then we need to do a network power cycle.
Steps to be followed for performing Network power cycle:
  • Unplug the power cable of both your modem and router.
  • Wait for 30 seconds.
  • Plug back the power cable of the modem and wait until all the lights are lit up in it.
  • Now plug back the power cable to the router and check for the lights in the router.
Modem & Internet lights will be lit and they will be solid (blue/green) in the router; it says that the Internet status is connected. Now you will be able to go online in the wired computers.
If still Modem & Internet lights are not solid in the router; it may be blinking in red/ amber it says that the Internet status is not connected. You will not be able to go online in the wired computers.
In this case you need to connect your computer directly to the modem and check whether you are able to go online. If you are not able to go online, then you need to contact your ISP and fix your issue with internet.
The above method is applicable only for Embarq, century link, Bell Sympatico, Bell Canada ISPs. Because these ISPs will have the IP address same as Belkin routers....
If nothing works then you need to contact your ISP and ask them to bridge the modem...Bridging the modem disables NAT in the modem and allows you to get a public IP in the modem.
click here to configure wireless part...
on May 09, 2010 • Computers & Internet
2helpful
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
1helpful
Our belkin g wireless router was working fine until a friend brought his laptop over connected to our router and now our own laptop will not connect to our router. Is there anything we can do?
Hi Friend,
We have to change the MAC Address Cloning in the router,please follwo the below mentioned steps,
1.Type 192.168.2.1,you will get a Belkin router setup page
2.On your left hand side, Click on MAC Address or MAC Address Cloning
3.It will ask fopr password,leave it blank and click on submit
4.then click on Clone,(It will assign your computers mac to the Router) ,now click on Apply changes
5.Then unplug the power cable of both modem and router,after 10 secs put only to the modem,after all lights got lit up,put the power cable to Router.
6.Then check the lights in router u will have all the lights in blue or green.
7.Try to scan and connect.You will be able to connect to the internet in wireless
Regards,
Ayyasam
2helpful
I just bought a Belkin Router Model # F5D8236-4. I have everything wired correctly, but the wireless light does not come on. I can't get the internet to come on to the computer I want to connect to? What...
Wireless light will lit up only if any wireless computer is connected to Belkin's wireless network.
First, connect to Belkin's wireless network that you can scan.
After you connect, try to go online
It ll work...
3helpful
3answers
Modem router light blinking (no wireless connection) F5D8631-4
Try restoring the Belkin back to the factory default by powering up the Belkin and pressing the RESET button on the back of the Belkin for 7 secs. Then connect a LAN cable from the computer to the Belkin, open IE browser and type the configuration IP address and configure the wireless settings ie. SSID, encryption etc. The computer wireless cards will need to be configured with the Belkin wireless settings to allow them to communicate with the Belkin.
Belkin wireless G+ usb adapter
AOL has been and will always have problem (had to do repairs on AOL computers since 1994)
If you have a DSL or Cable connection why pay again for AOL? That means you are paying twice for the same internet connection - and AOL causes lots of problems.
For AOL problems, it is best to contact AOL.
Grand Canyon Tech
Grand Canyon Tech
