U need to re-timed the engine. Check all four marks going across the two cam pully is lined up with the engine head surface.
Then check the crank pully alignment mark the single notche align to the mark on the timing cover
Sounds like you are having a thermostat problem. It sounds like it is sticking at times and you may also have a bad temp. sensor. At times, if the thermostat sticks in the closed position, the sensor in the outlet side of the t-stat housing will not read the proper engine temp..Next time it gives you problems, lift the hood and carefully check the temp. of both of the water hoses to the radiator. If the top hose feels hot and the lower hose is only warm, then the t-stat. is stuck in the closed position and needs to be replaced.
No, your car is set up for hydraulic transmission linkage and the Integra is a cable clutch. The mounting would also be a nightmare. The Integra's front motor mount is way different than the Accord and Prelude. Wiring harness would be another nightmare. Just find an Si, they are pretty cheap now.
did you continue to crank it to start ?
did you hear anything other than usual starter noise ?
you may have gotten lucky if no clanking or clicking noise ---don't try to start it again though
and that is timing belt not camshaft
for future knowledge when considering a vehicle for purchase ---ASK or find out if it's what's called an interference motor or the non interference design ---if you snap the belt on an interference design
alot of twin cams are --but I see a trend from automakers to get away from this --which they should
then albeit some or even major damage can occur ---the 91's civics 1,6 Single over head cam is a non interfernce design --now 1989 or 1992 on well that's another matter
I love my wifes 1991 civic dx ---to date only things ever to fail was the distributor and the timing belt and tensioner ---ps --think about replacing the water pump --front crankshaft seal as well while
you are in there replacing the timing belt ---do a coolant leak down test too --= 5 minutes
to check intake gaskets etc and head gasket --opportune time for a replacement
Yoy can buy the entire engine gasket set generally cheaper that a few individual one and keep
the others for future or give them to a new owner Someday --good 1 st cars --they are capable of 250,000 + easy ---key to longevity ---add an oil cooler with cooling fan set at the right temp with
fan --even better if you live in the mtns like I do
HAWK
