This is typically done when the rear brakes are serviced. I usually rotatoe my tires at every oil change, and adjust the rear brakes at the same time. Drum brakes are adjusted by turning the self-adjuster and rotating the drum until you feel a bit of friction.
Adjusters are on the cable neer the left rear brake.If they are not siezed then it's a piece of cake,just unlock the jam nuts and tighten.If they are siezed then you need hear and patience.
Lever (1), cable (2), spring (3) and backing plate (4)
Park brake shoe assembly 1500HD, 25 and 35 Series
Click to Enlarge
To install:
