I bought a refubished xbox elite in april and now I have 3 rings with code 0020. There is no way it overheated I had not played it for 3 days. The yesterday I played for about 30 minutes before I had to leave and everything was fine and today my son wanted to play so I turned it on and 3 rings. Will Microsoft fix this for free eventhough I am not the original owner? If not do you have any suggestions on how to fix it myself. I am getting conflicting solutions around the net for that code 0020. The console date is 2007-03-05. Thank You
Are you guys sure it has to be original owner?. if it definitly a 3 red lights job then it is covered by the 3 year warrenty. I think you can still have it replaced. You just go to the returns part of the xbox website put in the serial and your address and take it from there. they will know when it was manufactured and who registered it but you still can enter in a different address. then just print out the postage and some guy will turn up to collect it. usually you get a new xbox back in about a week they have stopped repairing them these days.
Microsoft only does warranty with the original owner , kinda stinks:(
Overheating just a secondary issue , The main problem is the G.P.U
has broken connections under it , giving you red lights. Don't
worry about all the error codes they are conflicting some times.
You have two options
1 have a shop that has a re-flow capabilities re-seat the
G.P.U and remount the Heatsink with out stressing the
P.C. board ( very important detail)
2 Do it your self, there are relatively simple procedures
that are safe for the unit and will get you back in
the game ( a standerd xclamp mod ) has more than likely
all ready been done on your unit if so you will need to
do some extra step to recover your unit , ill advise if needed
Rob
Red Ring of Death: Red Flashing XBOX 360 Lights Explained
Common Xbox 360 Red Ring Errors
The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error,
follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
