My blender works perfectly but I dropped the glass container and need to replace it. Where can I find a replacement. I have tried Breville and they no longer make the model. So no spare parts there. Any suggestions????My blender works perfectly but I dropped the glass container and need to replace it. Where can I find a replacement. I have tried Breville and they no longer make the model. So no spare parts there. Any suggestions????
We have broken our glass to and otherwise it works well. Wnyone a good glass they cannot use?We have broken our glass to and otherwise it works well. Wnyone a good glass they cannot use?
You can't post conmments that contain an email address.
I have bought a Thermomix and am therefore selling my Breville CBL10 BlendMaster Classic Work Top Blender for $50 plus postage. If anyone is interested i Live in Western Australia. My email is [email protected]
There is a store at Bondi Junction (Oxford street) where I purchased replacement blades as mine broke. Dont have their details though. Try tracking them down.
Yes I know the store it is called Oxford Appliance Parts on Bronte Road in Bondi Junction. Their website ishttp://www.oxfordparts.com.au/Yes I know the store it is called Oxford Appliance Parts on Bronte Road in Bondi Junction. Their website is http://www.oxfordparts.com.au/
google appliance spare parts in your country maybe google whatever the model number is and the words spare parts to see if you can find a local appliance spare part retailer
Breville CBL10 has been a fantastic appliance but now electrical section works at slow speed only so I will get rid of it, however the glass jug complete with lid, blade etc is still perfect. Does anyone need this part? I am in Rockhampton.
your blade assembly is corroded. take it off, and using a rag, grab the blades. using another rag, grab the other end (probably rubber) and turn CLOCKWISE - it's threaded reverse, so you have to turn to the right to loosen, not the left like usual. I had to clean out the rod that connects to the blades - it was all nasty and corroded. I cleaned it with my Dremel and regreased with a tube of grease I keep in the garage, cleaned all other parts with some Dawn, dried well, reassembled, and works almost like new. I'm guessing I ran it too long without pulsing the motor and the heat corroded the rod that's connected to the blades. OR you can buy a replacement blade unit for about $10 online on a blender parts site
You have to unscrew and disassemble the blades - pretty easy, just take two rags and grab the blades with one (so you don't cut yourself), and then turn the rubber piece on the other side COUNTER CLOCKWISE, opposite of what you would do to loosen. the rod that runs in the middle that's connected to the blades on mine was all corroded, so I sprayed it down with WD-40, took my Dremel to it and smoothed out the corrosion, added some fresh grease ($2 tube goes a long way), washed the other parts with some Dawn and dried completely, reassembled and it runs much better! Not sure how long it will last, but I have a feeling that one time I ran the blender for a long time instead of pulsing, and the grease that came with it couldn't handle the heat from it turning so long. Anyway good luck!
the top rubber piece could be worn enough that it is not engaging the pitcher. look at it carefully and see if the "teeth" of the rubber disc on top of the base has not cracked and worn away. a picture of the new one can be seen on the parts websites to compare I spent $10.00 for my replacement but i found them at other sites for $6.00. you will need a very skinny 7mm open ended wrench to get the old one off and it is left handed threads that means clockwise will loosen not tighten the part.i ground down my wrench but an ignition wrench from an auto store will usually be thin enough to reach the flats on the shaft under the rubber disc
where the blade is its cracked underneath. its a breville bl1 thanx debbie
