Plantronics 510 Voyager Headset - PLN-510 Headset Logo
Posted on Oct 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i put my 510 earpiece in the pairing mode
Anonymous
Level 2:
President:
  • Expert 987 Answers
  • Posted on Oct 20, 2009
Anonymous
Expert
Level 2:
President:
Answers
987
Questions
14
Helped
284702
Points
132
Press and hold the switch for about 30sec ...after that it will be in pairing mode ...and enter 0000 as passkey
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
589
Points
Hi, how do i turn on the pairing for a voyager 510 wireless earpiece? in would appreciate someones help....i am trying to pair it with a lg rumor touch cell phone and do not have a manual thank you
2 Related Answers
Anonymous
  • Posted on Mar 15, 2008
SOURCE: How do you put the LG earpiece in pairing mode???
0000 worked great for my LG to Motorola Headset Pairing. Thanks
Mike
casouzaj
CARLOS R SOUZA JR
  • 1118 Answers
  • Posted on Jul 10, 2010
SOURCE: Dont know how to put jabra bluetooth earpiece it
Start with your headset turned off. Then, press and hold the answer/end button, until the indicator light is steadily lit in blue. It is in paring mode now. Then, make the bluetooth application on the device you want to pair your headset with, search for new devices. After a while, the BT350 headset should appear in the device' screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
By the way, if your headset's user manual happens to be missing, feel free to download it from this location.
Hope it works for you.
Regards, Carlos
How do i connect my plantronics 510 voyager headset to my blackberry
Once you make your BlackBerry discoverable, then put the Plantronics Voyager 510 into pairing mode by holding the call control and volume up buttons at the same time until the headset flashes red and blue. Here is the link below for the 510 pairing instructions.
Plantronics Voyager 510 Pairing Instructions
Good luck from Headsets Direct!
tip
How to Pair or Connect the Plantronics 510 Bluetooth Headset to your Bluetooth...
1. Turn on Bluetooth within your phone - Consult phone instruction booklet
2. Put phone into pairing mode - Consult phone instruction booklet
3. Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
4. Select "Add new device" on your phone.
5. Select the Plantronics headset when prompted. Enter "0000" as passcode.
6. Your 510 headset will now have a continuous blue light blinking.
7. Choose "Yes" if your phones asks if you want to bond to the 510 bluetooth headset.
8. Your phone is now paired with the Plantronics 510 headset and ready for use.
on Jul 14, 2010 • Cell Phones
When trying to pair my plantronics voyager 50 to my iphone, i am attempting to get the blue and red light to flash by pushing the up volume and the call button. but no flashes occur, even after 60 seconds...
  1. Turn on Bluetooth within your phone. Put phone into pairing mode.Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
  2. Pick the headset for Plantronics when prompted. Enter "0000" (four zeros)
  3. you should now have a continuous blue light blinking.
  4. Choose "Yes" if your phones asks if you want to bond to the Voyager 510 bluetooth headset.
Good luck from Headsets Direct - 800-914-7996.
How do I put the unit in discover mode
Putting the Plantronics Voyager 510 into pairing mode:
With headset on, press and hold the call button and the volume up simultaneously until the headset begins to flash red and blue.
Select the Plantronics 510 headset in your phone when prompted and enter 0000 (4 zeros) as the PIN/passcode if prompted. When paired, the Voyager 510 headset should now have a continuous blinking blue light. Here is a link below for the step by step pairing instructions.
http://www.headsetsdirect.com/plantronics-voyager-510-bluetooth-pairing-instructions
20helpful
How do you sync a plantronics 510?
allanrecht
The steps below will show you how to put your Voyager 510 into pairing mode.
To put the headset into pairing mode:
1 - Start with the headset powered on (the headset will have a blue blinking light).
2 - Press in and hold the + side of the volume button (long, thin and silver) and the Call Control Button (on the
microphone boom, oval shaped) until the headset flashes red, blue, red, blue.
3 - Tell your phone to "Find the new Bluetooth device" (see the User Guide or call a local phone store).
4 - If the phone asks for a User Code or passkey, enter 0000 (four zeros).
Issken
20helpful
2answers
How to set it up with new phone how do i set up discoverable mode
  1. Turn on both the phone and the headset
  2. To put the headset into pairing mode, at the same time press the Call Control button (side of the headset) AND the volume button marked "+". When the status indicator light flashes between blue and red, you are in pairing mode.
  3. Now use your phones menu to search for bluetooth devices, you should see it say "PLT 510" on the screen. Note, this can take up to 2 minutes.
  4. When it asks for the passkey, enter "0000" (zeros). When the light on the headset turns blue you are successful.
  5. If this fails, try again
  6. If this fails again...reset the headset. To reset, do a long press of the MUTE and volume down buttons simultaneously for about 3 seconds, then try the procedure again.
2answers
Ear piece does not work. Station top light does not come on
The 500A base station is definitely compatible with the 510 earpiece. If the earpiece is turned off or unpaired the base station's red power light will be flashing. If the earpiece is already off, try turning it on by holding down the little black button on top. The base station will automatically try to find the earpiece and the blue light on top of the base will come on. If the earpiece is already on (slow flashing blue light on the mic boom) turn it off and back on again and wait for the base to find it.
Earpiece slipped off the plantronics bluetooth,and i want to know if there is anything to help put it together again.
my plantronics 510 voyager did the same thing. try putting the earpiece back on to the main bluetooth and wrapping a small rubber band BETWEEN THE TWO. the object is to put some opposing pressure on the earpiece to force it to stay on. it'll work at least till you get anoter earpiece
Top Plantronics Radio Communications Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
