SOURCE: Ricoh CL2000N Error Code SC230
The manual says this code means " BCU Received no Feedback from LD" I have no idea what that means, but maybe it will help a tech on hear tell you more.
SOURCE: Ricoh caplio r3 digital camera.
This has happened to me a couple of times. It appeared when the camera was getting a lot of use and it wouldn't turn off - it was jammed on. I had to leave it a few minutes and not touch it - turn it off, then it was ok. I think it was overheated!
SOURCE: Repair and service manual for Ricoh Aficio 250
Check with this website, they should be able to get you one
http://www.service-manual.net/ashop/catalogue.php?exp=&cat=283&gclid=COzWt96Ym5QCFSUqagodnl83tg
SOURCE: Solution for "code 373 ricoh aficio color 6513"
Hello sir; the error code you display is toner senser problem, now the first thing you have to do is make a full color copy find out which color missing then pull out developer unit from missing color the senser right underneath, replace it.
SOURCE: Ricoh 5510L Network Setup
Go to user tools-key op tools-network-tcp ip- ip address put the appropiate info in.(including gateway address.) then type the ip address into the top portion of a web browser an you should be in web image monitor. you configure the printer there. User name is admin no password. -Carl
driver of Benqi Dc C640 Digital Camera Sofftwer i want
