20 Most Recent
Ricoh Aficio GX3050N All-In-One Printer Questions & Answers
It says communication error on
Please :
- Check your ricoh driver on your PC ( you must have the driver installed at your PC)
- Check PC - printer cable connection ( It must connnected securely)
- Set your ricoh printer as default printer on PC ( Go to control panel, click printer, right click ricoh and choose default printer).
Regards, Jay
Wanna connect mulitple computers to
Yes, you can definitely share one printer to multiple computers. All you need to have is a ethernet hub or some call it network hub and Cat5 cable. Ethernet Hub is a simple, small and inexpensive gadget to connect multiple computers together.For the Cat5 cable is popularly known as LAN cable. For you to share your printer, connect it on a ethernet hub as well as your computers using a Cat5 cable. Once everything is connected to the Ethernet hub fix the network and that's it. Everyone that is on the network can use the printer.
I hope I answered your question.
Thanks a lot!
How to fix error 990???
http://forums.linux-foundation.org/read.php?30,2996
Date: October 31, 2008 02:18PM
ERR (990) ??? I turned it off and back on & still gives me this error code?
Date: January 09, 2009 03:26PM
This is a known manufacturer error. Call Ricoh Direct and talk to someone in Tech Support. If your product is registered with them, they will send you a new printer. You will have to ship the old one back in the same box the new one was shipped to you in, but they provide an RMA # so there isn't any charge.
I've moved relatively new ink cartridges between
well sure you can solve this problem and to disable the ink level monitoring utility, and to do so please follow the following steps:
Click start and click on RUN (else type RUN in search box if using Windows Vista or Windows 7)
Type msconfig in the RUN box
Click on the startup Tab on the top right hand side corner of the system configuration utility
Select the particular Ricoh utility in the list of startup items and disable the same (uncheck it)
Click on Apply and Close
Upon System restart you might get an option or warning of system configuration utility please check the box for don't show this message and click on close
That's it, issue resolved
In case you are unable to find the startup utility you may click on the option on the bottom to disable all, this would also help you improve the speed of computer as it would stop unnecessary startup items to load on system startup.
I keep getting error 999 when trying to print a
Hold online and escape button together and then turn the machine on while still holding down those two buttons. Continue to hold those buttons down until machine clears it self (will take 2 - 3 minutes).
I have Ricoh Aficio MP c2800, Machine say toner undetectable all four when i check system status and yellow, cyan is not show up on copies at all
If your Ricoh Aficio MP C2800 is showing "toner undetectable" messages for all four toner cartridges and the yellow and cyan colors are not showing up in copies, there may be several potential causes for this issue. Here are some troubleshooting steps to help you resolve the problem:
- Check Toner Cartridges: Ensure that all four toner cartridges are correctly installed and securely seated in their respective slots. Make sure there are no protective seals or tapes left on the cartridges.
- Shake Toner Cartridges: Sometimes, toner inside the cartridges can settle or clump, leading to detection issues. Gently shake each toner cartridge side to side to redistribute the toner evenly.
- Replace Toner Cartridges: If the toner cartridges are old, empty, or expired, replace them with new, genuine Ricoh toner cartridges.
- Clean Contacts: Dust or debris on the toner cartridge contacts can interfere with communication. Use a soft, lint-free cloth to clean the electrical contacts on both the toner cartridges and inside the printer.
- Check Developer Unit: The developer unit in the printer plays a crucial role in toner development and transfer. Ensure that the developer unit is clean and free from any obstructions.
- Perform a Firmware Update: Check if there are any firmware updates available for your Ricoh MP C2800 printer. Updating the firmware might address known issues and improve printer performance.
- Reset the Printer: Power off the printer, unplug it from the power source, wait for a few minutes, and then plug it back in. Power the printer on to see if the issue resolves.
- Check Toner Detection Sensors: The printer uses sensors to detect the presence of toner cartridges. Verify that these sensors are functioning correctly and not blocked by any debris.
- Perform a Factory Reset: As a last resort, you can try performing a factory reset on the printer. However, be aware that this will reset all settings to their defaults, and any custom configurations will be lost
