This is caused by the IAC valve. Over time the valve becomes gummy and inoperative. Get it replaced and the problem is solved. IAC stands for idle air control, hence the stalling concern.
I owned one of these. There is a groove under the butterfly horn of the throttle. There are 8 bolts and a $10 gasket. Often the EGR passage is clogged and it throws off the calibrations and when you clean this groove the engine will run much better.
Describe the noise.Is it a hiss,like something isn't connected tightly?Or is it a horn sound? IF it's a horn sound,it could be coming from a component right at the rear of the engine. I replaced one on my boy's Crown Vic.It's hard to do without having some good selections of 1/4"drives or small wrenches. That sound got so bad that people were getting mad at Justin because they thought he was sounding his horn at them. I don't remember the name of the component,but it cost me 50 bucks at Auto-Zone. don-ohio (:^D
There is a revised snorkle for the air supply to the idle air control valve. The design on yours would sometimes create this noise. Usually worse on cold starts. A good parts guy at a Ford dealership should be able to find the updated part for you.
If you would like further assistance on this problem, ask me in a comment here. Thank you for using FixYa. KL
fluid on the pad can cause the pad to stick and then slip--this can cause noise when the pad breaks loose from the disk. fix the leak and clean everything with brake cleaner (or put in new pads)
check your fuel pressure if you dont have enough pressure this will happen when the fuel pressure is good the system will just push the air out through the injectors or the fuel return line
Are u using the recommendedfuel ? if so try running a couple of cans of fuel injection upper cylinder cleaner through the system with the next few tanks of gas, try LUCAS brand, it is among the best, the next step is to have the engine de-carboned by the dealer, this works very well, you can also remove an octane selection jumper, it retards the timing 2 degrees, that will most times stop the ping.
