Samsung BlackJack II Smartphone Logo
Anonymous Posted on Oct 14, 2009
My keyboard won't light up any longer.is there anything i can do to fix? this is a samsung blackjack 2
Anonymous
Level 2:
New Friend:
  • Expert 105 Answers
  • Posted on Nov 15, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
105
Questions
0
Helped
20514
Points
252
If it just stops lighting its usually messed up and can be fixed by the factory if you send it back to them its usually happens when it getts wet and or dropped sorry hope this was helpful:)
1helpful
What is the unlock code for a samsung jack for fido in red deer alberta canada
The Lock/Unlock on a Samsung BlackJack II is for the Keyboard to lock press and hold the softkey for hanging up the phone until the word unlock appears in the lower left portion of the screen. To Unlock the keyboard press the power key on the top end of the phone until the screen lighyts up the press the soft key directly under the word "Unlock" then press the asterick button " * " this should unlock the keyboard.
Samsung Blackjack II Earpiece Speaker, SGH-I617 Blackjack 2 Audio Receiver i NEED THIS PART AND THE PART # IS 3009-001310
the earpiece speaker of my samsung i617 is not working,i cant hear anything but if i put in loud speaker i can hear it.
how can i fix my earpiece speaker?
Aug 28, 2009 • Cell Phones
2answers
I have a Samsung Blackjack 2 and i locked it and i
the only solution on it is hard reset the unit you are using.thats all i can say...try
It wont charge when on
Return to the carrier for warranty repair.
The blackjack 2 starts to have charge issues over time. The light comes on but it does not charge.
If you are out of warranty there are some options you can choose from
1. Get repaired
2. New phone
3. external charging source
The external battery charger runs about 20 dollars on ebay with an extra battery.
Check out the following link to find more about these options
Samsung BlackJack II not charging fix
Recocnizing micro sd card
The original Blackjack will not recognize anything larger than 2gb. Sorry, but you just wasted buying those 4 gb. cards. I found this out the hard way too when I bought my daughter a 4gb card for her Blackjack. I have a BJ2 which will recognize the 4gb cards.
My blackjack's keys wont work
First off, how do you know it's the keys, rather than something else? More details are always helpful. An important question is, can you see or hear anything at all, by any means? If someone calls you, does the screen light up?
If you see incoming calls, but can't answer them because the keys don't do anything, then I'd ask if the phone might have the keyboard locked. You'll be able to tell because you'll see "Unlock" in the lower left of the screen when someone calls or you press the power button (top left edge, above the screen). If it's locked, pressing the "..." button to the left of the wheel will tell you how to unlock it (just the "*" button down by the "0" button on my Blackjack).
If you don't see anything when someone calls, you might want to figure out if the phone is working at all.
A couple of ideas (sorry if any of these seem obvious - it's bad form to miss simple solutions):
1. Is the phone powered on? You can turn it on by holding down the power button (top left edge, above the screen) for several seconds. If you make it to 10 without the phone coming on, then it might be the screen, the battery, or the phone itself.
2. Is the battery dead? Try plugging the phone in and then holding down the power button, as above. If it still won't work, try removing the battery, then plugging it in and doing the same thing over again. When you plug the charger in, you should see a Duracell-like image on the screen, even if the phone is turned off. If you still don't get any sounds or anything on the screen, it sounds like the phone has serious trouble - probably needs professional help.
3. If you hear sounds ("swooshing" on mine) when you turn it on or off and the keyboard lights up, but don't see anything on the screen, it sounds like the screen might be bad - probably needs professional help.
4. Finally, you could try connecting it to your computer with the sync cable. I haven't done that with mine, so you'll have to read the instructioins, but it might let you know that the phone is working internally, but having communications problems through the keyboard and/or screen. If that's the case, you can try fixing it yourself or get an estimate from a professional. Good luck!
1helpful
Samsung Blackjack 2 . . .devise locked it then forgot the passwor
hi,
try do a soft reset of the TV. this will help you solve the problem
thanks you
Blackjack II Ringtone file corrupted
I had the same problem and I just got it fixed today. You need to backup anything you have on your phone then reset the whole thing. Here isthe link: http://www.wireless.att.com/support/tuto...
Hope this fixes your problem, so far it has fixed mine.
Rachel
2helpful
Blackjack 2 won't turn on
Hi svstskier,
This is actually a bug in the BlackJack II's firmware. If you power the BlackJack II off, but you're unable to power back on, try removing the battery for about 10 seconds, then reinsert the battery and power back on. The power button should work now.
(At the moment there's no permanent fix for this.)
Does that adequately resolve the issue?
Are you turning the BlackJack II off to conserve battery? While flying? Something else?
Thanks!
Jonathan
2answers
Keyboard lights
well i don't have something to say
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
