The timing belt broke. I had the head re-done. Now it will not run. It starts and runs obout 10-20 seconds and then shuts off like the fuel is being shut off.
Double check all connections, also hope your timing marks were lined up 100% on mark, sounds like timing may be off.or something was left unhooked, also scan computer for any codes. hope this helps.
i dont see how computer would need programing, it wasnt replaced. how about all the sensors are there any pinched wires, be careful sometimes it the most common mistake but people over look it be cause they are so fustrated. just take you r time and start from the begining and check all wiring, also if you hold the gas pedal to keep it running will it stay on,it may need tolearn idle and get lifters or rings oiled up.from sitting and the cleaning,try it.
Was the belt installed correctly
Yes. We have doubel and triple checked the time. I called a dealer and he said that it might have set a security in it when we took it apart. He said we would have to tow it to the dealer to find out if that is it and it will cost $77 to find out and reset it.
We have gone over everything over and over. Once it starts, you can sit and hold the RPM's at about 3,000.
It will run for about 20 seconds and then it just drops.
