YouTube Videos Logo
Posted on Oct 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Anything i try to watch on YOUTUBE stops and starts. I see the whole thing but in ten seconds bytes.
Anonymous
Level 2:
Sergeant:
Novelist:
  • Expert 191 Answers
  • Posted on Oct 11, 2009
Anonymous
Expert
Level 2:
Sergeant:
Novelist:
Answers
191
Questions
0
Helped
83103
Points
597
The video is buffering which is normal. A lot of buffering can mean an internet connection that is not quite fast enough. If you can do things that help with the performance of your internet connection, you can reduce the buffering attempts.
If you are dial-up, not much you are going to be able to do. Dial-up is not fast enough to support video.
If you are using high speed internet (DSL, cable, satellite), you can do things like restart the modem (unplug, wait 15 seconds, plug back in). If you have a router to connect mulitple PCs to your modem, you can restart the router (unplug, wait, plug in). Resetting router is especially useful if you stay connected all the time.
If you are connecting wireless to your modem/router, check the signal strength. Try to position your computer to get the best strength possible. To help boost signal, you can get hi-gain antennae for your modem/router. These will help boost the strength of the wireless signal as well as extend range.
How do I stop youtube from buffering?
You want it to bufferor you could not watch anything. Perhaps ypu are runningtoo many other apps so close them. Lastly your connection speed may be too low. You should want at least 3mb.
The push button function on swiss model 2423.11 bulova accutron.
Jesus I can't believe no one answered this guy with even an "I don't know." in 6 years.
If it's like my watch, it's for synchronizing the second hand. If you press the button on the minute mark from the NIST time web site, when your watch is ten seconds fast, the second hand will stop for ten seconds. This makes your watch match the time clock. The really cool thing is if your watch is SLOW, if you press the button on the minute mark when your watch is twenty seconds behind the NIST time web site, the second hand will SPEED UP until it matches the NIST time. Very cool and this is **totally from my memory** because I just got my watch back from Bulova but I forgot to ask about the button.
Youtube will only play for about 50 seconds and then it just sits there and will not play the rest of the video unless if i wait for ten minutes. My Shockwave is up to date is it just youtube?
not youtube but your internet service provider. if your have a rather slow connection, all videos you'll be watching will stop time to time to buffer. even though your shockwaveplayer is up to date.
2answers
Freezes every 3or 4 seconds
Let it run all the way through, then rerun it. With the computer cache having the whole video it will no longer freeze
Rick
2answers
Anytime i watch a video it will start then stop after a few seconds, then start again and stop. It will do this continually and with every video i watch.
what you need to do its try and let the whole video download for a few minutes before you try and watch it. it always works for me. good luck i hope i helped. :)
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Top YouTube Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
 Grubhead
Grubhead
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
