I have a 2002 Trailblazer. I have changed the passenger low beam light twice in 24 hours. There is signs of burn on the plug that goes into the light but the low beam is the only thing that has burned out. Can just the plug be replaced or does the entire assembly need replacement?
Check the wires to the plug for damage that could cause a short.do not touch the glass on a halogen bulb-the oil from your fingerprint can cause a 'hot spot' leading to premature failure. clean 'dirty' bulbw/alcohol & a clean cloth.
http://repairhelpcenter.blogspot.com/2012/01/passenger-side-low-beam-out.html
Low beam HID light goes out?
http://schematicsdiagram.blogspot.com/2012/01/low-beam-hid-light-goes-out.html
----------2007 Dodge Caliber: Low Beam Headlight Not working
http://technoanswers.blogspot.in/2012/06/2007-dodge-caliber-low-beam-headlight.html
-------------Chevy Tahoe: Low Beam Lamps are not working?
http://technoanswers.blogspot.in/2012/04/chevy-tahoe-low-beam-lamps-are-not.html
----------2001 Chevrolet Tahoe: Both Low Beam Lamps Not Working?
http://technoanswers.blogspot.in/2012/04/2001-chevrolet-tahoe-both-low-beam.html
--------------2002 Toyota Tacoma: Low Beams not working?
http://technoanswers.blogspot.in/2012/04/2002-toyota-tacoma-low-beams-not.html
-----------Low beam headlights Modification?
http://schematicsdiagram.blogspot.in/2012/04/low-beam-headlights-modification.html
-----------DRL and Low beams not working?
http://schematicsdiagram.blogspot.in/2012/04/drl-and-low-beams-not-working.html
-----------These will help.Thanks.
There is signs of burning on the plug. Can just the plug be replaced or does the entire assembly?
