Bluetother devices have a 4 digit code that allows them to be connected to another device. The phone or vehicle or other device will request the code of the device being synced. Then the pairing will take place.
contacted Sagem and they give me the password over ride its enter following, Menu-Menu-red button-menu that gives you access to the box and you can reset passwords etc hope that helps. (does work) !!!!
Was a repair of the ABS System done & the shop didn't clear the codes?
You don't reset much on a car,you clear data & that turns off the check light
That doesn't fix a problem & removes the data needed to do
If you don't want to chance loosing the radio or having a car on security lock out ,you use a code reader to clear codes,unless you know the system & the consequences
Its the 8TH digit on the VIN number. Its on a plate under you windshield in front of the driver. Look at it from outside the truck. You would think the PARTS guy would tell you that. Are you SURE it need injectors? very unusual.
To switch on the security code go into Tools/Settings/Security.
To unlock:
The default security code for Nokia is 12345 I need the IMEI (International Mobile Equipment Identity) number. Type this code in your phone to get it: *#06# you can also find it beneath the battery. Then I’ll give you the Master code to reset your Security code.
"Confucius he say: A bird in hand makes hard to blow nose."
