Hello.
To reset your TomTom device, do the following:
Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
If your device uses an SD card, remove it.
Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. On your model, the reset is on the bottom of the GPS.
Press the On/off button for at least 5 seconds.
If your device uses an SD card, insert the SD card.
This is a common problem on all TomTom GPS units it is a problem in the operating program of the GPS, the 1st thing you need to do is press the reset button, if the problem persists after that you will need
to call TomTom support to see if any updates are avil to address this problem, I could not find anything but perhaps they haven't published t to the internet yet, but in any case i suggest ou contact the support center fro your GPS, they are the only only one that can supply any updated software.
To setup the Access Point
To setup the Browser
http://end.sonyericsson.com/cws/support/phones/detailed/howtolockthekeypad/xperiax10?cc=il&lc=en
To activate automatic screen and keylock:
To lock the screen:
To unlock the screen:
Tip: You can change the path direction, by touching and holding at the top of the path and then flicking to the left or right.
hi have charged the battery before we went out ,the 700 has a hard drive no sd card and i have tried the reset button thanks BRYAN
