2006 Hyundai Sonata Logo
Posted on Oct 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 2006 Sonata is leaking from the top of the oil filter, what
Where do i put the o ring on the filter cap.
Anonymous
Level 2:
  • Expert 101 Answers
  • Posted on Oct 02, 2009
Anonymous
Expert
Level 2:
Answers
101
Questions
0
Helped
43505
Points
282
With more detail,I woild find a replacement at ur local salvage yard or buy a new one at ur local auto parts store,
1helpful
How to change the oil filter
Put the car on a lift or jacks. Since it has low clearnance you will need lower jacks or use a ramp.
Remove the oil cap and the oil filter. You may need a strap wrench if the oil filter is too tight to come off by hand.
Look for trap door under the metal cover underneath the car. Open the trap door and you will have access to the oil pan drain bolt.
Use 17mm socket to remove the drain bolt and catch oil into a basin.
Remove the oil filter from the oil cap housing. YOu will also have to remove a large and small oil ring as well as a washer. The new filter will come with those. The oil rings must go into the groove to prevent oil from leaking. The filter goes on the cap housing. The washer that comes with the oil filter goes with the drain plug. Take off the old washer drain plug and put on the new washer drain plug and drain bolt once all oil has poured out.
Ratchet in drain bolt and close the trap door. Put on oil filter by hand. Put in 7 quarts of 5w-30 oil. Check with the dipstick as you get to the last half quart.
Replace oil cap, start engine, and check for any indications of leaks.
Where is the oil filter on 2006 hyundai sonata 3.3 l dohc
It uses a filter element and cap, not a cartridge. Look for a black plastic dome on top of the engine, between the cylinder heads. There are a couple of o-rings to be very watchful for as well, so they do not become lost! There are (or were) two different filter elements available, so make sure to obtain the correct one.
2006 hyundai oil filter change
well the ring should stay on the oil filter if there was one on there when you took off the old one it came off and dont need it
Is there a certain torque you need to tighten the oil filter cap? If so what is it and also I have tried hand tighten and then turning a 1/4 turn with a oil filter wrench. this worked for a little while...
Tighten to 18 foot lbs. and be sure to replace the o-ring in the cap these are prone to nicks and than leaking, put clean oil on o-ring before putting back on housing!
2helpful
2answers
2006 BMW 530i with a slow/small oil leak.
Common oil leaking areas on that engine is the plastic lid on the oil filter,and the gasket in between the oil filter adapter and the engine block.I would suggest you take it to a qualified shop and have them diagnose the oil leak.
Oil filter housing leak
you may have left out the brass ring. Or put an extra one on there. Go back to the auto parts store. Carefully see what parts are included in the oil filter mechanism and replace them. two O-rings a brass ring and then the oil filter. press down on the top cap and tighten the 10mm bolt, that should seal it.
12helpful
2answers
Where`s oil filter 08 santa fe
It is located on the top of you engine compartment, under the hood, to the right (Driver Side) of the engine and left of your battery. You need to take off the plastic engine cover (two bolts and four screw nuts) to expose it. It is cylinder in shape with a black plastic cap, which screws off to show the oil filter. The filter is different than your normal one, it doesn't have a outside metal cover to it.
When you purchase your replacement filter, it will come with two "O" rings, one small and one big. The big one replaces the "O" ring at the top of the screw part of your black cap and the small one goes on the bottom of the same cap.
9helpful
5answers
2006 hyundai sonata oil filter leak
I finally figured this out. I was putting the o-ring on incorrectly. I actually had two o-rings installed.
The o-ring should not be visible when it is tightened down. The plastic should be touching the metal housing. The o-ring sits inside the housing, right above the threads, but not at the top. Two pictures attached._388.jpg
Top Hyundai Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Hyundai Expert? Answer questions, earn points and help others
