Zebra Symbol Technologies MC909X-G Series Barcode Scanner Logo
Posted on Oct 01, 2009
9090 batteries not holding charge
Our 9090 batteries are losing power very quickly. What is the life of a 9090 battery?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 08, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
505
Points
From what I've seen so far they will start giving you problems after 3y . but it might very depending on # of times it was recharged, is it recharged properly etc ...
tip
Battery life extension
All batteries lose their capacity to hold a charge over time, but how you take care of them can affect how quickly this occurs. To keep batteries better for longer, try to drain them nearly all the way before charging, and charge them fully every time. If you're not going to be using the battery for a while (a couple weeks or longer) drain it to about 80% before storing it. For laptops and other devices that often stay plugged in, fully drain and charge the battery about once a month. Doing these things can help slow down the degradation of the batteries in your gadgets.
on Mar 01, 2011 • Computers & Internet
Mercedes c200K battery losing life
Depends is it cold weather leaving them for a few days kills the battery duff battery will not hold charge most garages do free battery tests as they want you to buy from them or faulty earth faulty charging unit or you have a wiring short takibg power from battery there could be many reasons but i would go with first three first
Batter wont stay charge
Most laptop batteries have a life expectancy of two years or 400 to 450 charge and discharge cycles. After this time, the battery may lose the ability to charge or to hold a charge for substantial periods of time. When this happens, it's likely the battery needs replacement. However, troubleshooting can narrow the problem and ensure you are not wasting money on a battery replacement.
Check Power Adapter Turn the laptop off. Remove any power cords or power sources. Separate the battery from the bottom of the laptop. Slide or press the locking mechanism to unlock the battery. Slide the battery out of the battery compartment. Plug the power adapter into an electrical outlet. Insert the opposite end of the adapter into the charging outlet on the side of a laptop. Power on the laptop. If the laptop does not turn on, the power adapter is not correctly working. If the power adapter is not working, the battery can not charge. Replace the power adapter. If the laptop powers on, the power adapter is properly working. Clean Battery Contacts Turn the computer off. Remove any power cords or sources. Take the battery out of the battery compartment. Dip a cotton swab in isopropyl alcohol. Rub the dampened swab on the battery compartment and battery contacts. Dust and buildup can prevent battery contacts from properly charging. Slide the battery back into the battery compartment. b> Charge and Test Battery Plug the power adapter into the laptop. Charge the battery for six hours. Remove the power adapter. Turn the laptop on. If the laptop turns on and stays on for at least 30 minutes, the battery is holding a charge. If the laptop doesn't turn on or the battery doesn't power the laptop for at least 30 minutes, the battery should be replaced.
Battery Won't Charge Or Short Power Life In Notebook
http://www.daileyint.com/hmdpc/battery.htm
Laptop Battery Depot http://www.laptopbatterydepot.com/problems.asp - clean
Battery life... we've had the radio's for awhile now and are wondering why some of the batteries are holding charges like they were from the beginning and why some are losing their charge early? What is...
Don't know what the expected battery life is for the product. But all rechargeable batteries lose life everytime they are recharged and drained. This is normal. You could send it to the maufacturer and have a/new battery(s)installed into product. Or if you can remove the battery yourself, you may be able to buy replacements from manufacturer or Radioshack or where ever batteries are sold. If product(s) is/are still under warranty, then send to manufacturer for replacement.
3helpful
3answers
Message to change battery or connect AC
this means that your battery has very little remaining power. If you just charged the battery it means your battery is going bad. Replace the battery.
1helpful
3answers
My psp battery loses power "quickly" and charges very slow....
How old is your battery? You may want to think about buying a new one as it may be on it's way out. Even if it is fairly new you might have a lemon of a battery. It happens at times. IF your psp is new and your battery is doing this you should contact sony and see if they can replace your battery for free or a nominal charge.
Hi I have an Olympus SP-560UZ that eats batteries almost as fast as i can charge them. My batteries are Rechargeable NiMH 2700 and almost new. I am only able to take six to ten shots before the battery...
Hey donoman,
I am going on the assumption that these batteries are not new. Most rechargeable batteries lose their ability to hold a charge after time, and it might be time to invest in new batteries. Another cause of this could be that you are mixing older batteries with newer batteries, and by doing this the length of the charge is dependent on the weakest battery. Things that significantly affect battery life are camera flash, LCD screens, and battery temperature (the lower the temperature the quicker the battery will drain). Another thing to consider is when a rechargeable battery starts to fail they fail quickly, where disposable batteries generally have a longer life and drain at a more constant rate.
Sincerely,
Allan
Go Ahead. Use Us.
May 08, 2008 • Cameras
Batteries not holding charge
they have a battery tester software online free 15 days or so that would tell u maby did u buy generic power pack also
Top Zebra Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
