If you have any rubber fuel lines in the fuel system, I would replace them. Over a period of time the insides of the hoses swell up and stop the fuel flow to the engine.
Hi Thomas:
Sounds like it's not getting fuel right away.
I'd be checking the choke, and also perhaps try priming by pushing gas pedal all the way down twice, spin over 2 or 3 seconds, then pump gas pedal twice again, then try to start.
None of this is valid if it is a diesel.
Normally, you wouldn't need to do this to get the engine started. If you have a mechanical fuel pump ion the engine, just cranking the engine over should cause the pump to push gas into the carburetor. And if an electric pump, it should come on with the key in on.
But to prime, pour a small amount of gas down the throat of the carb, and crank. As the engine fires and runs, the pump should begin working and pushing fuel into the carb.
There is no trick, push the primer button as many times as it takes to 3/4 fill the bulb ( you cannot over prime it no matter how many times you push it ) pull the red start switch out and at the same time lift up until it locks up, crank the engine twice or until it fires, do not continue to crank, push the red stop button down half way, crank engine until it starts and runs, blip the trigger to bring to idle.
