ASUS P5PE-VM Motherboard Logo
Posted on Sep 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to update cmos setting of my motherboard - ASUS P5PE-VM Motherboard
Robert Nyilas
Level 3:
President:
  • Master 627 Answers
  • Posted on Sep 30, 2009
Robert Nyilas
Master
Level 3:
President:
Answers
627
Questions
0
Helped
329715
Points
2229
Go to this link
After that, top left corner below Download fill the textbox with P5PE and click on Search info.
From there you have to select the operating system, after that you'll find the newest bios patches.
Download the latest and flash it.
1helpful
2answers
I have using msi k8mm-v ms-7142 ver:1 motherboard with amd sampron 2500+processor its audio driver is not working i download and install ac97 audio from msi site but it is asking to enable bios audio...
You have to double check the cmos or bios settings which the audio are enabled mostly on integrated peripherals inside of you bios! Tap DEL key to enter bios setup.If the audio settings are enabled other solution is to upgrade your bios firmware. You can actually download the update from MSI official website. But be careful while updating your bios firmware, be sure to download the exact model of the motherboard and you must have back up battery or UPS while performing flashing your cmos because if interrupted while flashing causes of fluctuation your motherboard will be dead set.Always remember to back up your cmos before flashing it. After flashing your cmos, install again you downloaded audio driver. The audio driver must be compatible with your operating system in order to install the driver. Hope this works for you!
1helpful
Bios rom checksum error.. system halted
This error comes when there is low cmos voltage so motherboard flash memory forgot the bios settings.
For that open cpu and then pull cmos cell from mother board buy new cmos cell and replaced it.
Then when you power up the computer press F1 or F2 or "del" key to enter in bios and set time and date and boot option in bios then save settings.
Then it works again if it not works then you need to update firmware for your bios .
Let me know if you need further assistance.
Thanks for using FixYa.
Bios settings changed automatically
Have you tried to update the bios? One of the latest versions BIOS Update [DPP3510J.86A] 07/15/09. But verify to ensure that you download the correct bios for your board. There are a few options available. Also check the jumper pins for the bios on the motherboard normal or (default) setting is pins 1-2 jumped.
3answers
AFTER BIOS UPDATE PROBLEM
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
apolpo-
24
Unable to save date in m/b bios
make sure your using new cmos battery not yet been use and then set date in your bios and save it after finish.
still doesn't work?
try update your cmos that migth be the problem note! remember always take care of the risk on updating flashing cmos on power interuption never power off if still flashing. or if you update and flush it before it might be a bad flash of your cmos try bring it up to early state or restore your backup cmos firmware or download it to its main manufacture
2helpful
2answers
CMOS Battery do no work
Just change your CMOS battery with a new one and after that goto the bios settings and update the time and dare.
After that just save the settings and then check that the warning message is coming or not.
If its coming then it means you need to change the CMOS jumper settings.
11helpful
4answers
Cmos checksum bad...usb current status detected system shut down 15 sec
Situation Remedies If you have encountered this error and would like to fix your computer, here are some remedies for each situation:
CMOS Battery Not Functioning Properly: If you suspect your CMOS battery is not functioning properly you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all settings are lost, you can usually get them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computers manual or tech support to remove your battery. Take down the CMOS batteries information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have remedied the problem.
Your BIOS has Been Updated (either by you or possibly a virus): If your BIOS has been updated recently, your CMOS settings may have become reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer Was Shut Down Improperly: Sometimes when running MS Windows, if you shut down your laptop or desktop without first properly shutting down your operating system it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer before turning off the power. Usually this entails going into the Start Menu/ Turn Off Computer/ Shut Down. If you received the error, shut down the computer properly, if this is the cause of the error, the error message will not return.
Can,t overclock after update bios(foxconn p4m800p7ma)
Try clearing the CMOS (CMOS reset)...and restoring defualt bios
2answers
Wont startup
1.may be the smps(power supply) not be proper.check power supply......
2.processor may be corrupted
3.bios cell may not be working proper
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
