Microsoft Xbox 360 Elite Console Logo
Posted on Sep 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Plug in to 220volts,
My xbox was accidentally plug in to 220volts. now it is not working. what will i do
Anonymous
Level 2:
  • Expert 90 Answers
  • Posted on Sep 30, 2009
Anonymous
Expert
Level 2:
Answers
90
Questions
0
Helped
15623
Points
230
Well its has burnt the circuit...take it to your supplier quickly or contact a technician
Accidentally turned off power strip when xbox was on
Why would you be replacing cables while the unit was turned on in the first place?
Recommend you contact Xbox directly.
1helpful
Can i use 220v source to energizer charger chvcm4
you will need a reducing transformer 220volts to 120 volts, you can find one at Radio Shack or Fry's Electronics., European countries uses 220volts, and the plug configurations are different from those of the USA.it is recomended to take one of these transformers with you when you travel abroad.
I plugged 110 volts xbox 360 into 220 volts outlet. and it's dead. what will i do?
Unless the item has internal fuse, it is burned up.
Look for product manual.
Many times, there is a glass fuse rated for unit voltage.
Replace fuse.
Each fuse has specific markings.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Philips authorized service center in fairview, quezon city
Well, depending on how technical you are, you can:
1.) open the tv and find the fuse at the power source. This is soldered onto the board and will need to be replaced.
2.) Take it to an electronics repair store.
What's wrong with my Xbox 360? I turn it on it looks like it's working then looks like ive never played the game before.. no memory, no avatar, no gamer score?
It may be that you accidentally deleted your gamer tag. try recovering it from Xbox live. if you deleted your tag you may have also accidentally deleted your saves too which you cannot recover.
I Accidentally Plugged My Xbox 360 into a 220 v socket can i still fix my power supply
Ah that sounds dangerous. Well technically everything can be fixed, but it would be easier and probably cheaper to just buy a new one.
I accidentally kicked the power plug out of my 360 and now the wireless adapter only stays red and won't connect! is it dead? tried restarting the router and modem but, no luck.
its microsoft!!!!!!!!!! bugs galore!!!!!!!! unplug the wireless adapter while the xbox is off.........turn the xbox back on and let it load with the ethernet plugged in...turn the system off using the control after you have established a connection the the network......unplug the ethernet and reinstall the wireless....turn it back on and let it load.....it still might not work in which case you will have to power cycle one more time.........and oh yeah, check in your setting to make sure wireless adapters are activated...
GOOD LUCK!!!!
2helpful
2answers
Incorrect voltage input
Check the fuse. Otherwise there's another fuse at the low voltage transformer itself. it will be covered with plastic tape on the primary winding of the transformer. Just replace it and enjoy your music
Good luck
Destorted sound on xbox after three red rings
After you have now faced the RRoD (red ring of doom), your console can fail anytime on you now, now return the console to M$, they'll give u a new one.
http://en.wikipedia.org/wiki/RRoD#Three_flashing_red_lights
Xbox 360
It is probably fried. I would have it repaired by some who knows how to fix it.
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
