2003 Chrysler PT Cruiser Logo
Posted on Sep 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Still want to shoot into a thermal runaway.
What I've done,
is the new thermostat, old one looked like new.
New radiator, old one also looked like new.
Removed fan low speed relay so fan comes on with  high speed relay only.
I'm now suspecting that the main belt tensioner idle pulley has allowed belt slippage and lack of water pump flow.
Is this an off the wall guess?
Anonymous
Level 2:
Novelist:
  • Expert 99 Answers
  • Posted on Sep 29, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
99
Questions
0
Helped
40572
Points
269
First of try to understand exactly what part you mention exactly how they work or function
  1. please place a new low speed relay as it try to make out thermal heating cool at it's initial 1st stage level of heating so that the temperature remain maintain if thus it reaches the second level of heating then the high speed relay act at that time & the speed of radiator fan increase to get thermal heating in control.
  2. the thermostat regulate the heating temperature of the engine it senses the temperature & signal to the relay the relay then react according to the temperature level of engine at low heating it operate the low speed relay & high temperature it signal to high speed relay so the engine temperature does not rise to extended level of heating or overheating.
  3. see for thermostat valve is failure if that so replace it new sometime most of the mechanic change it or cancel it so that the temperature does not rise as this thermostat help engine maintain it's ideal temperature which is required by the engine for regular or good working even at extreme climatic condition.
  4. Do check for every tensioner or Ideal Bearing as far consider on the No. of miles or Km the vehicle has run according to us the tensioner or ideal bearing are suppose to be replace at an interval of 30000 to 35000 Km. but this replacement include both Engine timing belt & tensioner & ideal tensioner bearing.
  5. A water pump flow depend on the tension of the drive belt some vehicle come with water pump which drive on inner timing belt tension & some on the fan belt or external tension belt of engine.
for further more FAQ do send in or place your problem we will sort it out till then have a safe drive & happy motoring from siddhanth.....!
2answers
Why does water shoot up out of radiator while running, changed radiator and thermostat still no change.
have a compression test done as it appears that there is a head gasket or cracked head problem and the compression gasses are getting into the radiator.
I just put a new radiator in my 1995 Chrysler Lebaron and my fan wouldn't kick on, I've asked some people and they have all said I need to replace my thermostat? I've also checked the fuse
Did you TRANSFER the Temperature Sensor over to the new Radiator and did you Plug it in?
There is a RELAY that you may need to test or you may have an electrical problem going to the FANS? Remember you had to remove the Fans to install the Radiator but you have to Plug them in when you get done..
Hopefully you did not pinch a wire along the way...
2answers
2007 focus, 2.0 automatic overheating at highway speeds, but not at low speeds
Well you could have a bad water pump that is not circulating the water right while you driving you car on high speed but if you wan to try if is the thermostat take off and drive the car like that if the problem goes away just put a new thermostat
1999 Honda Civic LX Stalling/Overheating!!!
(I don't know much about cars so bear with me).
I've had problems of overheating previously where my car's thermostat would hit 140. I think I've fixed the issue, I've replaced the thermostat but it was still doing that and 2 hoses blew and needed to be replaced. I've had to consistently fill my radiator with 50/50 antifreeze on a daily basis to ensure it won't overheat, so far that seems to be keeping the peace.
But now as of 5 days ago, I'm experiencing these new issues of stalling. Upon taking my civic into my mechanic, his meter showed that there was a misfire in the 2nd cylinder a month prior and now all 4 are misfiring. He thought it was the head gasket at first. I had just recently replaced the spark plugs with NGK Platinums, new spark plug wires and a new distributor cap.
I've received many possible culprits to my problem consisting of possibly the Throttle Position Sensor, Fuel Filter/Injection, Distributor or a radiator cap. I'm financially strapped at the moment and only could afford the radiator cap which didn't solve anything, however my radiator is running on 80% water at the moment. I'm really at a loss and I feel like I've done what I could and I'm at my wits end. Please help my poor little Civic cheat death for a little longer.
1helpful
92' Ford Explorer is running hot. Changed the thermostat, water-pump and flushed out cooling system. The coolant is boiling in the radiator, and overflowing out of the coolant reservoir.
sounds like a blockage like a dodgy thermostat, id test it by boiling a jug and throwing your new thermostat in the boiling water and see if it opens, other than that you've pretty much done it all so id be looking at a blown head gasket. good luck :)
I put a new water pump and a new thermostst and my temp still slowly rises. or it could be that the water canister could be bad i really do need the help!!!!!!
heat rises can be a number of things,, is anything blocking the air flow through the radiator, are the cells in the radiator blocked or clogged,, look in through the cap refill for the radiator and see if its rusty if so flush the radiator, is the thermostat the recommended heat range for the motor? Is the fan working correctly,, any of these could cause your problem, once it reaches the correct heat range is the thermostat opening and the temp0 drops,, and here's one that I have to add , but no reflection on your repair abilities, But I've done it ,, so I know it happens,, is the thermostat put in the right direction, make sure the spring section is towards the motor
I have a toyota cressida 2.4gle 1992 model.My car heats up after i've travelled about 25km.I've put in a new radiator.The fan is working and i've also replaced the radiator cap,but it's...
Is the car actually heating up?Does the radiator boil?Have you looked at the temperature sending unit giving a bad temp.reading.?The thermostat needs looking at and also the head gasket.Hope this helps
2answers
Where is the thermostat located
Under the hood find radiator at front of the car on either left or right side of radiator is a fat hose that will be connected to the radiator. Follow that hose to the engine and it connects to the thermostat cover that is connected to the top of the engine with two bolts holding it on. Remove both bolts, Remove thermostat cover replace with new thermostat, Scrap off old gasket on both connecting sides place in new gasket (using a gasket sealer with the gasket wouldn't hurt to) replace both bolts only SNUG tight if using sealer let sit for a hour or two. your done!!
How do I locate the thermostat on the Nissan Maxima 1989?
The upper radiator hose connects to the thermostat housing . Loosen clamp and remove hose from housing nipple , there will be two bolts one on either side of the housing remove bolts lift housing and thermostat will be under it ,pay attention to the way it is facing before removing . remove old thermostat clean off old gasket seal install new gasket (it will come with the new thermostat ) install new thermostat face same direction as the old one was. reinstall housing and hose . refill radiator with antifreeze let car run till it warms to normal running temp check for leaks on hose and housing tighten clamp or bolts if needed if no leaks your done. Hope this helps.
5helpful
Need to change radiator on 2006 ford explorer
THE EASIEST WAY TO REPLACE THIS RADIATOR IS TO REMOVE THE FREON FROM THE AC SYSTEM, DISCONNECT THE LINES GOING TO THE AC CONDENSER, REMOVE THE FAN SHROUD TOP AND BOTTOM, THEN REMOVE THE 13MM BOLTS ON THE UPPER PART OF THE RADIATOR SUPPORTS. REMOVE THE AIR DIFLECTOR ON THE BOTTOM OF THE VEHICLE, REMOVE THE AIR FILTER ASSEMBLY. LAST YOU NEED THE TOOL TO DISCONNECT THE TRANS LINES. ONCE THIS IS DONE THE RADIATOR AND THE CONDENSER WILL COME OUT IN ONE PIECE. AFTER THIS IS DONE YOU CAN EASILY REMOVE THE RADIATOR FROM THE SUPPORT.
IF YOU DO NOT HAVE THE TOOL TO REMOVE THE TRANS LINES YOU CAN UNSCREW THE TRANS LINES FROM THE RADIATOR. YOU WILL HAVE TO REMOVE THE FITTINGS OFF THE NEW RADIATOR AND USE THE OLD ONES. ONCE YOU HAVE THE RADIATOR IN PUT THE FAN SHROUD BACK IN AND TIGHTEN THE BOLTS. THEN IF YOU HAD TO UNSCREW THE TRANS LINES DUE TO NO TOOL, REMOVE ONE OF THE FITTINGS OFF THE NEW RADIATOR AND SCREW THE OLD FIITING BACK IN AND TIGHTEN IT. THEN REMOVE THE OTHER TRANS FITTING AND SCREW IT IN USING THE OLD FITTING. DO NOT REMOVE BOTH OF THE TRANS FIITINGS ON THE NEW RADIATOR AT THE SAME TIME OR YOU WILL LOSE THE RESEVOIR IN THE RADIATOR. ONCE THIS IS ALL DONE EVACUATE THE AC SYSTEM, RECHARGE THE AC, FILL THE RADIATOR WITH COOLANT AND YOU SHOULD BE GOOD TO GO. I HIGHLY RECOMMEND REPLACING THE RADIATOR, THERMOSTAT, AND THE RADIATOR CAP AT THE SAME TIME. I BELIEVE THE THERMOSTATS IN THIS VEHICLE DO NOT OPEN AS DESIGNED WHICH CREATES VERY HIGH PRESSURE IN THE COOLING SYSTEM WHICH CAUSES THE RADIATOR TO FAIL PREMATURELY.
AFTER STARTING THE VEHICLE CHECK THE UPPER RADIATOR HOSE AND MAKE SURE IT IS NOT ROCK HARD, IF YOU DID NOT REPLACE THE THERMOSTAT. IF IT IS ROCK HARD REPLACE THE THERMOSTAT.
THINGS TO CHECK:
CHECK THE RAD/CONDESER SUPPORTS FOR CRACKS YOU MAY FIND THEY ARE BROKEN IF THEY ARE REPLACE THE SUPPORT. IT IS AVAILABLE FROM FORD.
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
