See if there are any fuses or relays on the switch that may be limiting the current flow. Make sure switch has direct connections. If needed, try a different switch or double check that your connections of switch have a metal to metal contact on unpainted surface
I have checked and the fuse is good and I tried a new one anyway I have the wiring schematic and there is no relay shown nor did I see one however I am with you in thinking that there has to be a voltage drop somewhere but I do not know where to look.
OK I have located the issue. Turns out that under the body on the frame is the negative cable connection, It was rusted. once cleaned and greased it works fine. It was the only connection I had not checked. Maybe it could be a first go to thing for someone else you try to help. You have to take the tire off to fix on this mower. Thanks
