Sony Cybershot S650 Digital Camera Logo
Posted on Dec 17, 2007
Cybershot 7.2 Hi - My camera can take photos on the twilight setting only. All other settings it appears to be recording, but not taking an actual photo. Is there a quick fix for this?
  • Anonymous Mar 02, 2008
    my camera opened and close the lens 3 times and them say that restart
Anonymous
Level 1:
  • Contributor 32 Answers
  • Posted on Jan 04, 2008
Anonymous
Contributor
Level 1:
Answers
32
Questions
0
Helped
6234
Points
30
Try resetting the camera. Take the batteries out for about five minutes and then re-insert them.
4helpful
SONY CYBERSHOT DSC - H3 DIGITAL CAMERA FLASH PROBLEM
Hi Jim,
Have you tried resetting all settings on the camera? On a Sony camera, it is called "initialize". The initialize setting is found by going to the menu, and tabbing down until you find an option called either "reset settings" or "initialize settings" and then confirm it.
Many times that will fix the issue, in case something has either been enabled/disabled on accident, or the software is sticking (which happens from time to time)
Cyber shot dsc-w1 stuck in movie mode
Hi!
When you rotate the mode dial, does camera change the mode? Maybe it switches only between video and twilight modes and when you set the dial to, for example, Auto mode, it's actually in Video mode? I have seen problems like this before with these cameras, mode dial had to be changed. If so, you should contact your local Sony service center and ask the price. If they ask too much, you can contact me at [email protected] and I can give you a better price.
Hope this helps!
Tom
2answers
Pictures are coming out blurry
On digital cameras it is always best to press the button half way down before taking the picture. This helps the camera focus, thus preventing blurry images. Always, always press the button half way down. Secondly, if you are still getting blurry pictures, there is a possiblity that the sensor in your camera is bad. I don't know how old your camera is or how long you've had it, but you would need to send it for repair, exchange it, or if it's under warranty maybe they'll send you a new one.
Using my memory card, i check my photos display with out date & time.
You will find a setting that will date/time stamp the actual image when it's taken. Please take a look in your manual. Most cameras have this feature.
When i take any photo the photo appears complete white?
You can try to bring it back to its original settings. Get the user's manual and try to reset it all. Let me know if it doesn't work.
May 01, 2009 • Cameras
1helpful
My sony camera gives this message and lenz will not close.
    This message appears when the lens assembly start malffunctioning. Therefore, You have to replace the Lens Block Assy. For this plz contact any nearest Sony Service Centre nearby to u.
Thanks for using fixya!
Take care.
VGA...?
Reset the camera... go to menu-initialize-ok ... like the previous solution... does yur camera after u take the photo say in red "RECORDING" for few seconds?
Terrible photos
if you want good photos with your k850i . go to camera settings then go into scenes then select twilight portrait. then go into seeting in camera mode turn on image stabilizer turn picture qulity into fine. note-- when u clicks photo keeep away your fingers from flash ............
SONY Cybershot 6.0 stuck on record
Initialize the Camera; select Initialize under Setup 2 Menu in the Main Menu. Reset the time and date. This should help
Cybershot dsc-w50 records movies instead of pictures
I had the same problem with my camera.  I found that changing the mode from Multi Burst to Normal allows the camera to take normal pictures.  Go to Menu and scroll over to Mode, then select Normal.
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
