Solar Ingraham 20 Program Electronic Timer W/random Switching Logo
Posted on Sep 25, 2009
Lost instructions for TE 109
Need to know how to set time of day.  am able to set the programs ok
  • Anonymous Nov 05, 2011
    How do I switch from military to cilivian time?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 02, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1842
Points
17
1. Press and hold SET until day flashes. Use arrow keys to set
2. Press SET again and hour should flash. Use arrow keys
3. Press SET again and minutes should flash. Use arrow keys
4, Press SET again to exit time-set mode.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
6171
Points
9
Here is a pretty good site for documentation:
http://217.155.210.129/timer/index.html
  • danwill51 Nov 05, 2010
    You saved me several hours of button pushing! Thanks
    DW
Anonymous
Level 1:
New Friend:
  • Posted on Dec 08, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1842
Points
Can't program my Ingraham TE190 timer. Help!
5helpful
I would like to know the torque settings for cylinder head for 1kz-te
Hi there:Cylinder tightening stages for a Toyota 1KZ-TE 3.0 turbo Diesel are...
Stage 1 39nm
Stage 2 90 degrees
Stage 3 90 degrees
Tightening sequence is as follows:
18-12-10-04-02-05-07-13-15
16-14-08-06-01-03-09-11-17
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
2answers
How to set specific dates to water with my T1030D? I don't need daily frequency for cool weather time. There is fequency dates to chooce on T1030, but not with T1030D.
1) Sept 2011.
If you have a T1030D timer instruction manual, then that would be helpful for many people.
Scan manual into .jpg format (file format) and then post images on Flickr.
Add a comment with link to those images so expert can access the information.
2) Currently the only instruction manual is the following, where you can also send information saying what your instruction manual says:
http://waterheatertimer.org/pdf/Instructions-for-setting-Gardena-T1030D.pdf
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
3) That being said:
Let me add some guessing, and then you can add a comment with what you observe.
Between us we might be able to work out a solution.
4) I don't think you can set specific dates on either T1030 or T1030D
It appears the T1030D is a weekly timer, just like T1030.
The word 'date' does not appear in T1030 manual except 'date of purchase.'
http://waterheatertimer.org/pdf/Gardena-1030-MANUAL.pdf
5) T1030D: each day of the 7-day week is broken into hour 1 through 24.
Each day can have between 1 to 3 settings. I think this is frequency.
You can set the watering run-time from 1 to 120 minutes for each set time.
40helpful
Vigoro 196-036 water timer manual -- need instructions on how to set timer for the Vigoor 196-036
Here is theinstruction:1. Install the battery2.Use left attor to decrease and right arrow to increase numbers < > to set current time to nearest hour at the time, noting AM and PM3. Repeat above instructions to set "start time: to desired time for day to begin watering4. Use left and right arro <> buttons to set "how often" (watering frequency) to select an hour/day increment (8 hours=3 times per day, 2 days=every other day).5. Use left and right buttons < > to set "how long" (watering duration) to select a min. or hr increment.6Activate the watering program by pressing the Program on/off buttin: a horizontal bar will be displayed to signify the program is on. Press the program on/off again to disable the programTo avoid accidentally changing the current program, the arrow button will be "locked out" or inaccessible if "program on" is selected.To create a new program, press Program on/off if necessary to disable current program.
Hi i get a set counter on my 220 what does that mean
I think it means that the machine is set up for a key counter , you need to enter the engineers service program mode and set copier 5 - 113 from 1 to zero.If you don't know what you are doing with the service program mode be very careful, if you get lost turn the machine off at its switch then start again.
enter service mode through the control panel -- press in sequence yellow button , 1, 0, 7 , press and hold orange button for at least 3 seconds - this should enter mode, repeat if it doesn't. press 1 to select copier OK, 5 to select mode OK , scan through using the previous and next buttons to 113, OKpress 0 then OK to change .exit mode by pressing exit repeatedly until normal screen appears
3helpful
2answers
I have an Intermatic timer Model HB71R and I've lost the instructions. Could you please send them to me? please send to the following email
Slide the middle left switch to TIME SET. Use the DAY, HOUR and MINUTE buttons to set the current day and time.
Slide the middle left switch to PROG.
When you set the switch to PROG, the number on the right on the LCD display will be a 1, and it will say ON above it. Adjust the DAY, HOUR and TIME for when you want your first program to turn on. Then press the bottom left EVENT button to proceed to set the OFF time for program 1. Adjust the DAY, HOUR and TIME for when you want your first program to turn off.
Press the bottom left EVENT button to move on to your 2nd event, and set the ON time. Again, press the bottom left button to move on to your second event OFF time. Continue in this way until you have programmed up to six different ON/OFF events. When you have programmed as many events as you need, slide the middle left switch to RUN at the center position.
To use the timer now, slide the upper left switch to AUTO at the middle position. The upper left switch, when moved to the right hand AUTO RAND position, will run the programs, but randomly start and stop them within a half hour of their programmed settings.
To use the timer manually, slide the upper left switch fully to the left to MAN, and press the bottom left switch to cycle between ON and OFF.
Hi i lost the instructions and don't know how to set the clock. please give me step by step once i reset the unit.
You posed under Aube T-1032 7-day programmable.
Aube makes a list of timers and each timer has different instructions.
For your convenience, I posted the Aube timers and manuals :
http://waterheatertimer.org/Aube-timers.html
I answer questions for free.
I am more than happy to write out the long list of instructions from the manual.
But the instructions apply only to the T1032.
They don't apply to the T-1034, T-1035, T-1052, T-1054, T-1070, T-1073.
If you would like me to write out instructions for one of the other timers, add a comment and tell me which timer.
T-1032 Manual
Set current time on T-1032:
Press and hold reset button
Display should be visible
Press Hour button to set current hour with AM or PM
Press MIN button to set current minutes
Press DAY button until current day shows (for example TU for Tuesday)
Close cover and press cover to confirm times
Programming overview:
Make a chart of your programs before starting to avoid conflicts in programming.
You can set 7 different programs
Program1 program2 program3 through program7
Each program has ON and OFF
First you set program1 ON with times and days of operation
And then you set program1 OFF with times and days of operation
Programming:
a) program1 ON
Press PGM button until the display appears as below:
P1 ON means you are ready to set program1 ON
Press the Day button to select days of operation for program1 ON
Press Hour to set hour am or pm for program1 ON
Press MIN to set minute for program1 ON
b) program1 OFF
Press PGM button until display shows: P1 OFF
The display will also show the the same Days you selected for program1 ON
Press Hour to set hour am or pm for program1 OFF
Press MIN to set minute for program1 OFF
c) To set program2, press PGM button until P2 ON displays
Repeat steps above to set all 7 programs.
d) To finish programming, close cover and push in cover
e) Select operating Mode.
Press and hold the cover until AUTO displays.
f) Press in cover for manual override.
7helpful
2answers
Date setting for cash register casio TE-100
Turn key to program mode. Type date as YYMMDD Press X/TIME (maybe labelled X/ DATE TIME) Press CLEAR ---------------------------------------------------------------------------------------------------
For those of you needing a Casio TE-100 manual, c-tech has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Top Solar Hardware & Accessories Experts
john h
Are you a Solar Hardware and Accessory Expert? Answer questions, earn points and help others
