I assume the fuses are OK.
The power then goes through the pressure switch....then to the compressor.......what happens when A/C is selected....engine running and pressure switch jumped?
Do you have a running compressor now........don't run it to long.......because it looks like you don't have enough refrigerant in the system to close the pressure switch.....75% ........or you may have a bad pressure switch 25%.
Did this just happen?? ck the cycling switch, its located at that big silver can on the pass side, in front of the firewall. if you wiggle the wires or tap on it, and the a/c compressor starts working, replace it.
Fig. Typical alternator mounting
To install:
Install or connect the following:
Alternator
Upper bolt. Do not tighten
Mounting bracket
Two bolts for the air conditioning compressor
Tighten bolts to 18 ft. lbs. (25 Nm)
Connector and wiring
Power steering pump
Drive belt
Negative battery cable
Engine splash guards, if equipped
