2001 ford taurus with check engine light on. code is P0125, which i was told was the engine coolant temperature sensor and i replaced that and the thermostat. Here I am now 1 week later, check engine light is on and code is the same P0125.
Make sure you replaced the right one there are two sensor's for the coolant, one takes coolant temp and the other one runs the fans for the radiator. Both are located on drivers side of the block. 2 wire leads on each how ever both are different in sending readings to the computer.Both look just alike also. Just make sure you replaced the right one. Or replace both.
