Hi Linda Remove fuse box cover and you should see a grid inside showing all locations for fuses and size of fuse used Don't EVER fit a higher rated fuse as you may have a short in the wiring and cause a fire!! Cig lightes have heavy wires and fuses make sure it is FREE to pop out when heated!! Good luck cheers Dave
? 2:34
www.youtube.com/watch?v=lCkpdRQBfNM
Dec 10, 2012 - Uploaded by crabjunkie2
The new fuel pump and sending unit are in the tank and all the lines are ... on to install the new harness pigtail. that does not come with the pump. this ... The joy of replacing34ft.motorhome fuel pump - Duration: 7:52. by crabjunkie2 6,459 views. 7:52 ... 1988 Fleetwood Bounder 454 engine running strong.
Seems that whoever fitted Left Turn Signal, might have messed up some wireing ! If your starting problems started after you had turn signal fitted, the tell Worksop / Dealer who did your repair. If you had problems starting before Turn Repair, then take to Garage for investigation
the wiring schematics for the chassis (vehicle ) will be in a workshop manual
the electric schematics for the home section will be (should be ) available from the body builder (Manufacturer)who fitted the home section.
You have an electric window right? if so the motor brushes are most likely stuck ( common concern), try hitting the bottom front of door panel with palm of your hand while holding the switch to down or up, if the window springs to life the motor is defective, in any event you need to pull the door panel and test the motor for 12 volt signal to one of the terminals, 12 volt signal will reverse on the connector depending which direction the switch is held to operate the window. If the 12 volts is prsent replace the motor, I wopuld recommend rockauto web site for best price.
