2004 Toyota Solara Logo
Anonymous Posted on Sep 14, 2009
99 camery solara...ratlingnoise front left wheel,
99 camery solara...ratling noise front left wheel, shock tower when hit small bumps
  • Anonymous Mar 23, 2014
    crash front end minor damage but will not turn over where is the fuel shut off relay shitch
Anonymous
Level 3:
President:
  • Master 333 Answers
  • Posted on Sep 14, 2009
Anonymous
Master
Level 3:
President:
Answers
333
Questions
0
Helped
339582
Points
1660
Strut tops are a common failure on the 97-01 era Camry/Solaras.
They will make a hollow rattle sound whenever you hit bumps or uneven pavement.
They can be replaced one at a time, and do not require strut replacement if your old struts are still in good shape.
Replacement does require a strut compressor and an alignment afterwards, placing it outside the scope of most do-it-yourselfers.
It is labeled "suspension support" in the following diagram. The bearing below it is typically replaced at the same time.
Testimonial: "i think you are right on. when the car was new i had these replaced once but warrenty covered it. thanks for your response."
1helpful
My terios 2006 make tiny noise on front left shock while drive off road
check shock bushings and shock shaft play, the shaft that moves up and down inside the shock and is attached at the top mounting, as a problem with either can cause a noise.
1helpful
2answers
2helpful
2answers
I have done shocks bilsteins front sway bar eibach brakes diff gasket and cover performance stering stablizer all tie rods all 4 bALLJOINTS NEW 20 INCH RIMS AND BRAND NEW TIRES FUTERA GOODYEARS 3 DIF...
I can think of two things not easily seen that can cause a banging when hitting small bumps;
The sway bar end links could be loose or broken.
The rear shock bolts, the lower bolt that holds the shock onto the rear axle, I've seen that mounting hole down there get enlarged, allowing the shock bolt to move about when hitting small bumps, causing a banging sound.
Check those two things out.
2answers
I need help with my 1994 pontaic grand am. I just bought the car and it has a terrible clunking noise in the front mostly when I turn the wheel. What could this be? Could it be tie rod, cv joints,shocks or...
Jack up the wheel and see if it has play up and down and left and right. Have someone watch inboard as you move it. A bad cluck will usually show itself.
3helpful
2answers
My front end is making very loud noises every time
same thing thats wrong wth mine ur bushings r bad. replace ur upper and lower ball joint and dont no proper name 4 it but outer tie rod goes to bushing on wheel change it.thats what im trying to figure out how to change.good luck
1helpful
Front suspension rattles and makes bumping noises when I drive over bumps (even small bumps) and when I turn the wheel either left or right. Possibly a ball/joint problem?
It could be, but check shock bushings, control arm bushings, sway bar and brackets. There are anumber of things that can cause a rattle. The first thing to be done is jack the truck up mput it on stands and start checking before replaceing parts. Pay close attention to shocks bushings and anything rubber.
Clanking noise coming from rear of 99 Jeep Grand Cherokee
check bushings on the pan hard rod and or spring seats
1helpful
2answers
Clanking noise under front drivers side - small bumps and turns...
CV joints yes look at the rubber boots for damage. You can get a replacement boot but if you do remove all the old grease to remove any dirt that is cousing your problem.
Noise...driving over bumps...it sound like the front struts
If its a squeeking noise the rubber bushes on the shocks or the lower contol arm are worn out, if its a grinding noise it could be the shock itself. If it happens when you turn, a clucking noise might indicate a worn cv joint, or a worn wheel bearing. These are all things that need to be replaced by a professional mechanic, if you have the tools, the bushes might not be too hard to do yourself though. Hope this helps!
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
