Air leak through the top head exhaust port. • Nothing ... head valve or the seal located on the top of the cylinder (the part the driver ... Look to see if the piston top of the driver is aligned in the ... Solution: Remove and replace trigger valve (if.Missing: question
Keep your framing nailer in top working condition and save time and money with a ...O-rings that cause air leaks, a trigger valve that won't fire, or a leaking cylinder seal ...then replace the rings one at a time, matching each one to its replacement. Install the new bumpers, piston seals and piston stops and reinstall the cap.
The problem is wear on the sides of the driver blade. With the constant up/down movement of the driver against either side of the nose plate, it eventually narrows enough to allow part of the fine wire 71 series staple to find it's way between the driver blade and the inside wall of the nose plate. A new driver blade cures this completely. Rainco tackers have become a bit rare but the good news is, they're actually manufactured by Fasco and the Fasco driver fits into the Rainco piston by the removal of a single pin to allow the old blade out, replace with the new Fasco blade, re-insert the pin into the piston, then re-assemble the gun and you're away.
Hello from FASCO ITALY. Pls let us have yr complete email address and we will send you the manual and the schematics. Our email is [email protected] best regards FASCO
Some models have small screws on the face plate that can be unscrewed to release pressure or a spring clip to release. You can also push the plunger back into stapler with a thin narrow srewdriver, the staple may fall out.
Remove gas tank is best way, 16 gal tank is mounted on drivers side, 19 gal. tank is in the rear of truck, send me you VIN # and I'll let you know for sure what size fuel tank you have, hope this was very helpful.
Fasco has been out of business for several years. The motors are still available. You will need to find the model number off your old unit. Once you have that model number you can find the replacement motor at one of these websites.
