ASUS P5V800-MX Motherboard Logo
Posted on Sep 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lga motherboard no display, processor doesn't heat
Powers up, but no beep, no display, processor does not heat up
Anonymous
Level 2:
  • Expert 53 Answers
  • Posted on Sep 07, 2009
Anonymous
Expert
Level 2:
Answers
53
Questions
0
Helped
19887
Points
126
If your processor does not heat up it's probably dead.. try running it without the fan and see if the heat sink still doesn't heat up
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 28, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
561
Points
No display matherboard
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jan 03, 2013
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
0
Helped
1108
Points
15
Okay , first of all this is called Date shortage , or let's call it data error , if the fan runs it means the motherboard accepted the voltage from the powersupply and it's runing it , okay , next is the data on screen , first check by your eyes if any thing looks wierd on board , ofcourse you will take the ram off and clean the slides as a first step as well , in many cases its the problem , ok next if every thing looks ok on the board then you need to look on the cpu circute , measure all the mosfets , directions of track , and the problem will be there , good luck
I am using a intel Dh61ww board with intel i3 2100 processor. When i switch on the pc the cpu fan rotates and halts.no display. pls help me.
The steps I would take would be : 1 make sure you have a power supply with the proper power connections and at least 500 Watts 2 remove and reset the power connections, try to boot 3 disconnect all hard drives and cd/dvd's, try to boot 4 remove all ram/memory sticks, try to boot and listen for the beep or beeps if it doesn't beep and still shuts off, you have a bad motherboard and/or cpu if it does beep, you need to try different ram
I need the best, fastest, most powerful and recent CPU and RAM available for the AcerPower Series 661GX-M7 motherboard; can it use a dual core processor?
Welcome to Fixya. If you want to upgrade your Processor you can use a dual core cpu. I proivded the list of processor that is compatible with your motherboard. By the way the socket of your motherboard is a LGA 775
Lga 775 Processors
Thanbks for using Fixya.
Every thing is working fine but no display as i changed the display & also checked the same display on another set it is working ok changed display ic but still same problem
Power off your computer and remove the smps 24 pin connector to the motherboard and short the green and black pin and see if the SMPS is working if not replace the smps.
Remove memory from the memory slot and switch on the computer if you hear beeps clean the memory or change it with new one that fixes the memory slot
If no beeps by removing the memory then remove the processor fan and clean it with soft cloth and apply thin layer of heat sink compound and switch on the computer
If you still not hear the beeps then change the processor
If still no beeps take the motherboard to a chip level Technion the secondary power supply or the clock,reset etc in the mother board has gone wrong or not producing them
2helpful
2answers
Board runs shows to be on runs but no beep and no display. No beep even when processor or memory removed.
The problem is in the processor or in the board to check first change the processor sutable for the socket and switchon the computer still the computer doesnt work check the secondery power supply thats four pin from the smps to the motherboard check all the FET and the capacitor in the powersupply also the 32khz crystel and the 14.182khz crystel and the clock ic
1helpful
MSI H55M-P31 board & having 2 2GB DDR3 modules and I7 Processors, installed memory on dual channel and sytem beeps 3 time and no display
Depending upon which BIOS make is installed in your computer, 3 beep means RAM fault.
Check the specification of your motherboard for the recommended RAM.
Reseat the RAM nodules in the motherboard.
Remove the RAM and get them tested at your friendly computer repair shop.
2helpful
ASUS P5Q3 with Xeon CPU
Yes, it will work. However it depends on which one you buy. Here's one that will work with that particular motherboard.
First, visit this website. Now search for, "Xeon" (Without the quotes, though). Click the second result on the list, which should be the, "Intel Xeon E3110 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor Model BX80570E3110 - Retail." That processor is a 45NM LGA-775 processor, which Asus claims that motherboard can support 45NM LGA-775 processor.
Let me know if I can assist you further, or if I need to explain anything in more detail. If this solves your question, please rate the solution.
I have a mecer computer, LGA 775 motherboard asus and the problem is the computer turns on when switching on and there is no display it beeps non stop . CPU and power supply fans are working ,lights goes...
continuous beeping is Power supply, motherboard, cpu, or keyboard problem. somecases it can also be the memory.
start with the memory then cpu and powersupply and finally motherboard.
let me know if the beep code changes as you change components, count the short and long beeps.
2helpful
2answers
No Beep No Display
motherboard problem motherboard can't display when switch on, the cpu fan faster no beeping . I had change power supply, but same.Check the keyboard LED,Not flash.I had remove the ram but can't hear beep. PC speaker ok conferm. Monitor display tested monitor its ok . But no comming display. Can you help me? How i can solve this problem?
4answers
No post no beep no video
you sure that the 4pin power connector coneected to your mobo
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
