Is media player , paying the songs, What is the version of the media player ? What is the application error code number ? I'll let you know the solution of this issue , Once you post the answer of these questions.
Control Panel / Administrative Tools / Event Manager
Windows 10 in startup apps go to Administrative Tools / Event Manager
Right Click start menu click event Viewer
once there look to left and expand WIndows Logs Click on Applications and wait for them to load See my pictures i found an error then I clicked on it and it told me what app.
If you don't have event viewer turned on you won't get anything. Then just google turn on event viewer your OS = (winodws 10, Windows 8 etc. turn it on reboot once the error occurs it is recorded go to event viewer and see results.
This issue may occur if the portable player was formatted via Windows Explorer. Follow these steps to correct this issue: NOTE: If the message you receive is Format OK? , select Cancel . 1. Connect the player to the computer. 2. Click Start and then click My Computer . NOTE: If the Portable Device box appears, click Cancel . 3. In the My Computer window, under Other , double click the icon for your portable player. 4. In the My Computer [Name of your device] window, right click the Internal Storage icon and then click Format from the menu. 5. In the Format box, click OK . 6. In the Format Complete box, click OK . 7. Close the My Computer windows. 8. Disconnect the portable player from the computer. 9. If it is not on, press the power button to turn it on. 10. Press the selector button repeatedly until Settings is highlighted. 11. Press the Play / Pause button. 12. Press the selector button repeatedly until Format is highlighted. 13. Press the Play / Pause button. 14. Press the selector button one time to highlight OK . 15. Press the Play / Pause button. 16. Once the player has finished setting up, Music Library will appear in the display and you can now use your portable player. 17. Test the player for proper functionality. If the error still occurs, reset the player by pressing the RESET button with a small pin or similar object. The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required.
You will have to uninstall everything that is made by adobe. Adobe flash player, adobe active x. After unstalling that, that should let you put the adobe reader back. Then download the other program I mention earlier.
you need to reinstall windows media player using the windows disc... also, you can try to use the windows repair feature.. just boot with your windows CD and pick repair my copy of windows..
Apparently, you computer has some unexpected software running during the startup. In order to get ride of these software, you could check your register table manualy by regedit or download this software, which will help you to find if there are any suspect software running at the startup.
If you are running two versions of ASP.NET, you may get HTTP:/1.1 500 Internal Server Error when creating a new Web project or opening an existing Web project in Visual Studio. This problem may occur when IIS is not sure what version of ASP.NET to use or where to locate ASP.NET files. One of the following solutions should fix the problem. Solution 1.
Remove web.config file from inetpub/wwwroot directory
Go to IIS, Right click on Default web site / All tasks / Check server extensions and let it run
Reset IIS by right click on IIS or call iisreset from Run command
Solution 2.
Install ASP.NET again using the following command from your Run command: C:WINNTMicrosoft.NETFrameworkv1.1.4322aspnet_regiis.exe Make sure to change the windows folder and ASP.NET version folder with the version what you want to install
Reset IIS
Solution 3. Applies to Windows Server 2003 Note: This is a Microsoft KB article: When you try to create a new Microsoft ASP.NET 1.1 application after you change the script mapping of the existing ASP.NET 1.1 Web application to ASP.NET 1.0 on a Microsoft Windows Server 2003-based computer, you may receive the following error message: The Web server reported the following error when attempting to create or open the Web project located at the following URL: 'http://localhost/822319ev1'. 'HTTP/1.1 500 Internal Server Error'. CAUSE This issue occurs because Windows Server 2003 does not allow two versions of ASP.NET to run in the same application pool. WORKAROUND To work around the problem, do one of the following: Restart the IIS before you create a new ASP.NET 1.1 application. At the command prompt type the following command: iisreset OR - Create an ASP.NET application in a separate application pool. Create the script-mapped application (ASP.NET 1.0) in a separate application pool -- for example, in the ScriptMapappPool application pool. Then, create a new ASP.NET 1.1 application in an application pool other than ScriptMapappPool. For more information about how to create an application pool, visit the following Microsoft Web site: Configuring Application Pools http://msdn.microsoft.com/en-us/library/1kdfe21k(VS.80).aspx
the only thing that you can do for this error message is to reload the operating system on the blackberry. You have to have the blackberry desktop manager installed on your computer first. Once the program is installed then perform the following
To run Application Loader on your computer, follow these steps:
Connect the handheld to the computer (insert the handheld in the cradle or connect directly by USB cable).
Note: The handheld must
remain connected throughout the entire process or the handheld’s
applications may not work properly. If a password is enabled, it must
be entered before the handheld connects to a computer. See Password not accepted when connected to the BlackBerry Desktop Manager.
Verify that a pop-up window appears when the handheld is recognized.
Click ApplicationLoader if the pop-up window does not appear.
Click Update Now.
Note: (This option only appears if new device software is available).
Click Next to open the 'Handheld Application Selection' window.
Each application lists (along with its file size) with a check box and an 'Action' item.
Review the following information about items that appear in the 'Action' column:
Install: Appears when an application is not present on the handheld.
The application loads on the handheld.
Update: Appears when the application version on the handheld is older than the version available with the Application Loader tool.
The most recent version of the application loads on the handheld.
None: Appears when the application version on the handheld is the same as the version available with the Application Loader tool.
The application does not change on the handheld.
Downgrade: Appears when the application
version on the handheld is more recent than the version available with
The older version of the application loads on the handheld.
Remove: Appears when a check box is cleared beside an application and that application was already present on the handheld.
The application is removed from the handheld.
Note: For more information on a particular application, select the application, then click Details.
The handheld’s standard system software is also listed in the 'Handheld
Application Selection' window. The software must be loaded on the
handheld. The check box cannot be cleared.
Click Next.< been have selections all>
The 'Application Data Backup' window appears.
Verify that the first option is selected by default.
Note: This option automatically backs up handheld applications and data. Data restores after the handheld software reloads.
The actions that occur during the loading process appear.
Verify that the handheld resets.
Note: This process may take a few minutes.
Click Close to return to the Desktop Manager.
Verify that the Application Loader indicates whether or not the process is successful.
Note: If the loading process is not successful,
verify that the handheld is connected to computer properly. Repeat the
above procedure if there was a connection error.
Start Internet Explorer.
2.
On the Tools menu, point to Pop-up Blocker, and then click Pop-up Blocker Settings.
3.
In the Address of Web site to allow box, type http://v5.windowsupdate.microsoft.com, and then click Add.
4.
Click Close to close the Pop-up Blocker Settings dialog box.
