Cell Phones Logo
Posted on Sep 04, 2009
Help!! I purchased my first LG Env3 phone a couple of months ago. My service provider is Verizon Wireless. I returned the phone a week later as it would not hold a charge more than a few hours. I am now on my THIRD replacement Env3 pnone and I am having the same problem. The phone will not hold a charge. I live in an area that does not get cell phone reception, so I don't even use the phone when I'm home. The phone says "searching for signal" when I am home and the bars usually have a 1x on them. My last Env3 that I got a few days ago held a charge for less than 12 hours. I didn't even use this phone as I've been home the entire time and I don't get cell reception at my house. I have all the settings on the phone that could drain the battery turned down or off. Can anyone please explain to me what is going on? Someone mentioned that since I am in an area that does not get cell service that the phone is constantly searching for a cell signal and therefore draining the battery. PLEASE HELP, as I am going crazy!! Thank you!
How to copy contact list from verizon lg env3 no longer connected to verizon to a new phone?
you can take it to a store and have them connect it to a PST machine, they charge for this service
My son has washed his brandnew cell phone :( Can I
you can contact the mobile service provider......
My env3 was dropped in a pool about 6 months ago. til this day, it will only show the verizon start up and thats it. what should i do to make it work again?
I deal with these type of situations here at the shop daily. My advice is, put it on eBay and sell it for parts. Let the buyer know it has water damage.
The cost to replace the phone would be less than the cost to repair it. And, repairing it doesn't mean that the same problem won't reoccur a week or two afterward.
The phone is only good for parts now.
1helpful
My enV3 wont recieve or send text messages
hi there, its very simple to fix
call the customer service of your service provider ( AT&T,Vodafone,Verizon etc)....they will set up message center number on your phone ...and send you sim updates ....and then you will get the text message options
cheers
My enV3 is only a couple weeks old. All of a sudden it won't keep the correct time. I have to open the flip in order for the time to be corrected. What is wrong with it?
Couple weeks old ??? return it for adjustment ... dont jeopardize your warranty.
Most electronics devices these days get the time from the network.
1helpful
My env3 will randomly turn it's self off.
Mine was doing the same thing.I remove the battery for a few min. a couple times a week and I also turn it off at nite.It seems to have fixed the problem with mine.Good luck
1helpful
2answers
Can't get new Jabra BT8040 to connect to LG Env3
I have the env Touch and the Jabra Halo. Initially, I had a problem pairing the two, then I realized that I was not following the directions properly. The manual shows two sections for pairing ("first time pairing" and "later pairing"). I was following the instructions for the former when I should have been following the latter. I also failed to notice that the BT indicator was flashing blue and not solid blue, as it needs to be, for pairing mode. So, if you haven't already done so, follow the instructions for "later pairing" here. Make sure that you see the SOLID blue light on the BT indicator on the headset when you try to pair.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
