If it is a belt noise, sprinkling baby powder on the belt will make the noise go away. Apply liberaly with engine off onto the belt and start the vehicle. The belt may have gotten coolant on it and this will cause the chirp. Also a defective belt tensioner will cause the belt to chirp
Depends on where the noise is coming from. Could be a serpentine belt, or one of the pulley bearings. Or something else. You could take the belt off and run the engine to see if the noise stops.
it can be a number of things ac clutch idler pulley trencher alternator power steering water pump and belt most likely is an old belt because its stiff and slips when cold it warms up the belt is more flexible and it grabs beater the trencher can be weak and with the cold belt it can slip
3500 rpms is about 80 mph. Is this noise in 1st, 2nd & 3rd gear? Is check engine light on?
Chirping could be accessory belt noise. Spray them one at a time with belt dresing to see if it goes away and which belt is doing it.
Sounds like your serpentine belt is dried out.Replace your belt make sure belt tensioner is ok,or you can make sure that it is your belt by using a old candle or belt dressing that you can purchase from your local parts store.While engine is running VERY carefully touch the candle to the ribbed side of the belt and let the wax rub off onto the belt the squeak or chirp should change or go away.Or just spray the belt dressing on per the directions on the can.
An easy way to get a good idea of where the noise is coming from is to use a short peice of wood like a broom handle , hold it to your ear and touch different places around the where the noise seems to come from. If it is in the belt area spray brake clean in small bursts at each pulley noting when the squek quiets or goes away.
one or more of the pulley's is defective, most likely the tensioner pulley, but check them all for wear and side to side movement which indicates a worn bearing, this causes the belt to not run true and chirp.
It's possible that the alternator is making the chirp noise (bearing) but I would try this first. Start the engine and allow the engine to idle and open the hood and take a spray can of WD40 and shoot a short burst onto the bottom side of the belt and pulley. Dont spray allot as this will cause the belt to slip. The WD40 is to lube the pulley grooves and belt a slight bit. Hope this works!
No quick fix. If you are lucky, it is just the flexplate snapped loose from the torque converter. There is usually a door that you take off to access the 4 bolts that hold the flex plate to the converter. Remove that door to see if the bolts have sheared off.
It shouldn't just fall off unless it broke from age, you did not say how old miles wise the belt was, if you replaced the belt and there is still noise you will have to check everything the belt turns, but most likely one of the idler or the tension-er pulley has a bad bearing in it, check everything by turning it and feeling for roughness in the bearings.
may sound like a faulty water pump. How is the engine temp?
