Roller lifter adjustment 5.7 chevy vortec 1999
Crank the engine until the mark on the damper aligns with the TDC mark on the timing tab and the engine is in #1 firing position.
To adjust a valve back off the adjusting nut until lash is felt at the pushrod. Tighten the nut until all lash is removed. This can be determined by rotating the pushrods with your fngers. When all lash is removed the pushrod will stop rotating. When all play is removed rotate the nut one full turn.
With the engine in #1 firing position the following valves can be adjusted:
Exhaust 1,3,4,8
Intake 1,2,5,7
Crank engine one full revolution - The following valves can now be adjusted:
Exhaust 2,5,6,7
Intake 3,4,6,8
I need to know if the pushrods go from long to short or short to long
