Hello. Have you actually seen the water flowing thriugh the paddle? I suggest taking the washer out of its home. Remove the arm in question. Spray a good amount of CLR on the mounting hub and through the arm Calcium does build up and cause the force of water to be less than needed to rotate the arm. Its also ok to run some CLR in the washer once a month when its empty to keep it running calcium free. Thank you , Quinn
