Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
Joe M. Posted on Aug 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Timing Belt replacement for a Craftsman air compressor
When replacing the timing belt, do I need to sync the pulleys for the drive motor and the piston rod? Or can I just replace the timing belt over both pullies?
Anonymous
Level 2:
  • Expert 60 Answers
  • Posted on Aug 19, 2009
Anonymous
Expert
Level 2:
Answers
60
Questions
0
Helped
16362
Points
178
You just replace the belt, timing is not nessescary.
2answers
How to set valve timing on the 1990 3.0 cressida
To install:
  1. Install the oil pump drive gear and tighten the 16 ft. lbs. (22 Nm).
  2. Using a suitable seal installer, install a new crankshaft timing gear seal. Install the gear.
  3. Temporarily install the idler pulley and tension spring.
  4. If using the old belt, check the rotation direction chalk mark placed on the timing belt during disassembly.
  5. Install the timing belt on the crankshaft pulley.
  6. Install the lower timing belt cover, air conditioning idler pulley bracket, compressor bracket and the lower timing belt cover retaining bolts and nuts. Install the pollution system air pipe assembly.
  7. Install the crankshaft pulley and pulley retaining bolt and torque to specification.
  8. Turn the crankshaft pulley and align its groove with the 0 mark on the lower timing belt cover.
  9. Install the camshaft timing pulleys and timing belt as follows:
    1. Turn the crankshaft pulley and align its groove with the 0 mark on the No. 1 timing belt cover. If the engine has not been disturbed, the engine should still be in this position.
    2. Align the alignment marks on the camshaft timing pulleys and the No. 2 timing belt cover. Install the timing pulley.
    3. Install the straight pin into the hole.
    4. When replacing the camshaft or the camshaft timing pulley. Always align the center holes of the camshaft and timing pulleys and insert the straight pin. When reusing the camshaft or camshaft timing pulleys, check that the straight pin hole position is in the same position it was at disassembly, insert the straight pin. Install the plate washer and pulley bolt.
    5. Using a suitable camshaft pulley holding tool, hold the pulley and tighten the pulley bolts to 36 ft. lbs. (49 Nm).
    6. Check that the matchmarks on the camshaft timing pulley are aligned with those on the No. 2 timing belt cover.
    7. Install the timing belt to the intake camshaft timing pulley, the exhaust camshaft timing pulley and the idler pulley.
    8. Loosen the idler pulley mount bolt until the pulley is moved slightly by the spring tension. Tighten the idler pulley mount bolt to 36 ft. lbs. (49 Nm).
    9. Check that the timing belt tension is equal all the way through. Turn the crankshaft pulley 2 revolutions clockwise from TDC to TDC.
    10. Check that the alignment marks on the camshaft timing pulleys are aligned with those on the No. 2 timing belt cover.
    11. If the marks do not align, remove the belt and install it again.
    12. Install the No. 3 timing cover gasket, cover and retaining bolts.
    13. Install the power steering pump belt.
    14. Install the four bolts, fan clutch, water pump pulley and fan shroud.
    15. Install the fan shroud mounting nuts.
    16. Tighten the fan belt adjusting bolt and nut of the power steering pump.
    17. Install the 4 bolts to the fluid coupling (fan clutch) flange.
  10. Install the air conditioning drive belt.
  11. Install the thermostat and water outlet along with it retaining bolts.
  12. Install the spark plugs and spark plug wires.
  13. Install the radiator assembly along with the radiator hoses.
  14. Install the drive belts and adjust as necessary.
  15. Install the air cleaner case assembly with the air intake connector.
  16. Refill the coolant system.
  17. Reconnect the negative battery cable. Connect a timing light and tachometer.
  18. Start the engine and set the ignition timing. Recheck the idle speed adjustment. Check for leaks and add coolant as necessary.
Whistling drive belts. I have used belt dressing; it hasn't worked. How to change the belts?
All Mitsubishi cars pretty much hide the water pump under the timing belt. You should buy all new belts for the car and if you have 150,000+ miles consider replacing the water pump at the same time.
You will have to take off the power steering belt .
First , take off the negative battery cable so you do not blow an expensive fuse on the positive battery cable clamp. Facing the back of the car , reach UNDER the alternator and loosen the bolt on the bottom right side, now loosen the bolt on the adjuster block on top, you can now turn the adjuster bolt and move the alternator to change the belt.
To take off the steering pump belt on the front of the motor, you need to loosen the nut on the back side of the pulley it holds the adjuster pulley in place . With the adjuster pulley loose , you can use the adjuster bolt to move the pulley to adjust the steering pump belt.
Now take off the upper belt cover, support the motor, take off the motor mount, jack up the right front corner of the car, take off the front right tire, take off the engine plastic under cover.
Line up the TDC timing mark on the cover to the mark on the pulley, check that the dot on the cam lines up with the timing arrow on the head, take off the lower pulleys,
take off the lower engine cover, observe the timing marks/arrows and highlight with paint (crank marks and cam marks should all line up if not , put the lower cover and pulley back on and rotate the crankshaft one full turn.), loosen the timing belt tensioner pulley ,take off the timing belt, counter balancer belt if there is one. Now you can unbolt the water pump, scrape the gasket, and replace it.
The good news is, if you have tools,a compressor, an air gun (for lower pulley bolt), patience , and four to eight hours to kill, you can actually save money and do it your self.
Need to know timing marks
REMOVAL
1. Disconnect negative battery cable.
2. Loosen power steering lock bolts and nuts accordingly and remove tension from power steering (P/S) and/or air conditioning (A/C) compressor drive belt.
3. Remove P/S and/or A/C drive belt.
4. Loosen generator mounting bolts and adjusting bolt.
5. Remove generator bolts.
6. Remove water pump pulley.
7. Remove crankshaft pulley.
8. Remove upper and lower timing belt covers.
9. Turn crankshaft so that timing mark on timing belt pulley is aligned with timing mark on engine.
10. Check that "I" mark on intake camshaft pulley is aligned with mark on seal plate and "E" mark on exhaust camshaft pulley is aligned with mark on seal plate.
Do not move camshaft or crankshaft once timing marks have been correctly positioned.
11. Loosen tensioner pulley lock bolt.
12. Protect timing belt with a rag.
13. Remove tensioner pulley.
14. Remove timing belt. Mark the direction of timing belt rotation (on the timing belt) for proper reinstallation.
INSTALLATION
1. Install tensioner pulley. Replace tensioner spring whenever timing belt is replaced.
2. Pull tensioner pulley to its furthest point and tighten lock bolt.
3. Check that timing mark on timing belt pulley is aligned with timing mark on engine.
4. Check that "I" mark on intake camshaft pulley is aligned with mark on seal plate and "E" mark on exhaust camshaft pulley is aligned with mark on seal plate.
If existing timing belt is being reused, install belt in proper rotation direction marked prior to removal.
5. Install timing belt onto timing belt pulley first, then idler pulley, exhaust camshaft pulley, intake camshaft pulley, and tensioner pulley in that order.
6. Check that there is no looseness in belt between idler pulley and exhaust camshaft pulley or between intake and exhaust camshaft pulleys.
7. Loosen tensioner pulley lock bolt and allow tensioner spring to apply tension to timing belt.
Do not add additional tension.
8. Tighten tensioner pulley lock bolt to specified torque.
Tightening torque:28~38 lb-ft (38~51 N·m, 3.9~5.2 kg-m)
9. Rotate crankshaft two full revolutions (clockwise only) and align timing mark on timing belt pulley with timing mark on engine block.
10. Check that "I" mark on intake camshaft pulley and "E" mark on exhaust camshaft pulley are aligned with marks on seal plate.
11. If they are not aligned, remove timing belt and start process from tensioner installation.
12. Measure timing belt deflection by applying moderate pressure midway between camshaft pulleys. If deflection is not correct, repeat from tensioner installation.
Deflection pressure:22 Ib. (98 N, 10 kg)Deflection:0.39~0.50 in. (11~13 mm)
13. Install lower and upper timing belt covers in that order.
Tightening torque:5.8~8.0 Ib-ft (7.9~10.7 N·m, 0.8~1.1 kg-m)
14. Install timing belt guide plate and crankshaft pulley.
Tightening torque:9.0~12.6 lb-ft (12.3~17.2 N·m, 1.3~1.8 kg-m)
15. Install water pump pulley.
16. Install generator belt and adjust the tension.
17. Install P/S and/or A/C drive belt and adjust the tension.
18. Connect negative battery cable.
INSPECTION
Never forcefully twist, turn inside out or bend timing belt. Do not allow oil or grease to come in contact with timing belt.
1. Replace timing belt if it is contaminated with oil or grease.
2. Check timing belt for uneven wear, fraying, peeling, cracking and hardening. Replace timing belt as necessary.
3. Bend timing belt into a "U" shape as shown in figure. Distance "A" must be at least 1.0 in (25 mm).
4. Inspect both idler pulley and tensioner pulley for uneven wear and smooth bearing operation.
5. Inspect camshaft pulleys and timing belt pulley for broken teeth or damage.
Replace any component that shows damage, excessive wear, or that appears prone to a possible failure.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
1helpful
Need a diagram of how to replace timing belt
2helpful
Need to replace & install a new timing belt on a 2002 mitsubishi galant es 2.4L
All Mitsubishi cars pretty much hide the water pump under the timing belt. You should buy all new belts for the car and if you have 150,000+ miles consider replacing the water pump at the same time.You will have to take off the power steering belt, the alternator belt, the upper belt cover, support the motor, take off the motor mount, jack up the right front corner of the car, take off the front right tire, take off the engine plastic under cover, line up the TDC timing mark, take off the lower pulleys, take off the lower engine cover, observe the timing marks/arrows and highlight with paint, take off the timing belt, counter balancer belt if there is one, and now you can unbolt the water pump, scrape the gasket, and replace it. Now the good news, if you have tools,a compressor, an air gun(for lower pulley bolt), patience , and four to eight hours to kill, you can actually save money and do it your self.
How do i cange a timing belt on 03lancer oz rally timing belt needs to be changed
You should buy all new belts and a water pump for the car. You will have to take off the power steering belt, the alternator belt, the upper belt cover, support the motor, take off the motor mount, take off the front wheel , take off the engine under covers , line up the TDC timing mark(pulley to cover), take off the lower pulleys, take off the lower cover, take off the timing belt, water pump belt, and now you can unbolt the water pump, scrape the gasket, and replace it. If you put it back together , do not replace the water pump and it goes bad you will kick your self . Now the good news, if you have tools,a compressor, an air gun(for lower pulley bolt), patience , and four to eight hours to kill, you can actually save money and do it your self.
5helpful
2answers
Need diagram to put timingbelt on 2001 kia sportage
prev.gif next.gif Timing Belt Removal & Installation SOHC To Remove:
  1. Disconnect battery negative cable.
  2. Remove fresh air duct.
  3. Drain engine coolant into an appropriate container and retighten radiator drain plug.
  4. Remove upper radiator hose.
  5. Remove fan clutch assembly bolts.
  6. Remove 5 cooling fan shroud bolts.
  7. Remove fan shroud and fan as an assembly.
  8. Loosen alternator mounting bolts and remove drive belt from pulley.
  9. Remove fan pulley.
  10. Remove 4 cooling fan assembly bolts.
  11. Remove cooling fan assembly.
  12. Remove 4 bolts and upper timing belt cover.
  13. Remove 2 lower bolts and lower timing belt cover.
  14. Loosen adjusting bolt and remove A/C belt.
  15. Remove alternator belt.
  16. Loosen power steering pump lock bolt and mounting bolt.
  17. Remove drive belt from crankshaft damper. Camshaft timing marks kia-03-20-7032.gif
  18. Turn crankshaft until timing mark on front housing and the arrow "2" on the camshaft pulley align.
  19. Remove 5 bolts and remove damper.
  20. Remove timing belt guide from timing belt pulley.
  21. Loosen tensioner lock bolt.
  22. Pry tensioner away from timing belt and tighten lock bolt to relieve tension on the timing belt. NOTE: Mark the direction of timing belt rotation on the belt if it is being reused.
  23. Remove timing belt.
To Install:
NOTE: Timing belt pulley timing mark and timing mark must be aligned.
NOTE: The arrow at "2" on camshaft pulley must be aligned with timing mark on front housing.
  1. Install timing belt with minimal slack from timing belt pulley to water pump and from water pump to camshaft pulley.
  2. Loosen tensioner lock bolt until tension is applied to timing belt. CAUTION
    Do not turn crankshaft counterclockwise.
  3. Turn crankshaft pulley 2 full turns clockwise and ensure timing marks are properly aligned.
  4. Tighten tensioner lock bolt to 33 ft lb (45 Nm).
  5. Apply a force of 21 lb to timing belt midway between idler pulley and camshaft pulley.
    • Deflection should measure 0.43-0.51 inch (11-13 mm)
    NOTE: if timing belt deflection is incorrect remove timing belt and install NEW tensioner spring.
  6. Install timing belt guide.
  7. Install crankshaft damper pulley.
  8. Install 5 crankshaft damper pulley bolts. Tighten bolts to 132 in lb (15 Nm).
  9. Install power steering pump drive belt.
  10. Adjust power steering pump drive belt tension and tighten lock bolt and mounting bolt.
  11. Install alternator drive belt.
  12. Install A/C drive belt.
  13. Install lower timing belt cover and bolts. Tighten bolts to 84 in lb (10 Nm).
  14. Install upper timing belt cover and bolts. Tighten bolts to 84 in lb (10 Nm).
  15. Install cooling fan assembly and 4 bolts. Tighten bolts to 27 ft lb (37 Nm).
  16. Install fan pulley.
  17. Install fan clutch and shroud as an assembly. Tighten bolts to 74 in lb (8 Nm).
  18. Tighten 4 cooling fan nuts to 16 ft lb (22 Nm).
  19. Adjust alternator belt tension and tighten alternator mounting bolts.
  20. Install upper radiator hose.
  21. Install fresh air duct.
  22. Connect battery negative cable.
  23. Refill/bleed cooling system.
DOHC To Remove:
  3. Remove 5 cooling fan shroud bolts and 4 thermo-modulated fan nuts.
  4. Remove 4 thermo-modulated fan shroud fasteners.
  5. Remove generator drive belt.
  6. Remove fan pulley (located above crankshaft pulley).
  7. Remove 4 bolts and splash shield (located under front of vehicle).
  8. Remove A/C drive belt and power steering drive belt. Timing Belt Removal kia-03-20-7097.gif
  9. Remove 5 bolts and upper timing belt cover.
  10. Remove 2 bolts and lower timing belt cover.
  11. Loosen tensioner lock bolt and pivot tensioner pulley outboard.
  12. Retighten tensioner lock bolt. NOTE: Mark timing belt for rotation if it is being reused.
  13. Remove timing belt.
To Install:
  1. Align marks on timing belt pulley and pump body. Camshaft pulley alignment marks 79245g28.gif
  2. Align marks on camshaft pulleys with alignment marks on seal plate.
  3. Install timing belt. NOTE: No looseness should exist on the tension side and at the camshaft pulleys.
  4. Loosen tensioner lock bolt.
  5. Turn crankshaft 2 revolutions in direction of rotation and check that timing marks are still in alignment.
  6. Tighten timing belt tension lock bolt to 27-38 ft lb (32-52 Nm).
  7. Apply a force of 22 lbs to timing belt between camshaft sprockets.
    • Belt deflection should measure 0.30-0.33 in (7.5-8.5 mm)
    NOTE: Replace tensioner spring if timing belt deflection is excessive.
  8. Install lower timing belt cover.
  9. Install upper timing belt cover.
  10. Install power steering drive belt and adjust belt tension.
  11. Install fan pulley.
  12. Install generator drive belt and adjust belt tension.
  13. Install A/C drive belt and adjust belt tension.
  14. Install splash guard.
  15. Install fan and fan shroud.
  16. Install 4 fan bolts. Tighten to 24 ft lb (33 Nm).
  17. Install fan shroud mounting bolts.
  18. Install fresh air duct.
  19. Connect hose to resonance chamber.
  20. Connect battery negative cable.
Replacing a the belt on a portable air compressor - craftsman
hi mate if the pump is connected then it doesnt have a belt its direct drive and if the motor is seperate from the pump unit then it belt driven i dont understand as the picture is a direct drive (no belt)
Can't disconnect the piston arm on a Craftsman air compressor
It is reverse thread, if you have a small torch heat it up to where it's warm tothe touch then tap it with a ball peen hammer to oosen it up then try it. let me know if this helps and thanks for Using fix-ya.
1helpful
86733GH3 REPAR TIMING BELT
3.0l Mitsubishi 6 cylinder.
support engine... remove engine mount... remove alternator, power stearing pump, compressor (if equipt) do not remove hoses from power stearing pump or compressor move them out of the way were they wont get damaged. Remove the tension pulley for the serpentine belt, and the tensioner for the compressor belt if equipt. then remove the compressor mounting bracket. Next remove the engine mounting plate and the crank pulley and balancer assembly. you should now be able to remove the the 3 piece timing cover. Once removed remove the tensioner spring from the water pump and loosen the tensioner nut. Remove the belt. At this point it is also recommended to replace the water pump and plumbing as well. The water pump service life is aproximately the same as the timing belt at 60,000 miles. This engine in stock form is a non interfering type engine. Meaning that moving the cams or crank out of sync will not cause damage. Turn each of the cams over by hand and line them up with the timing mark on the top of the back cover with the marks on the pulleys. Using a wrench turn the crank so that the pulley mark lines up with the mark cast into the block. replace the belt, tensioner spring (replace tensioner if warn) and tighten the tensioner bolt. roll the crank over 2 complete turns forward and recheck the cams to make sure the marks are still lined up. roll the crank backwards and recheck the timing marks again. (this process is much easier done with the plugs removed.) If everything is still lined up correctly (crank at TDC and cam pulleys pointing to each designated mark on the covers.) reassemble the cover and assessorys in the reverse order that they were removed and reinstall the old motor mount or replace if needed.
Top Craftsman Air Tools & Compressors Experts
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
