We have a Whirlpool model GX39SLEG gas stove. The oven is acting up. When we turn it on it heats then randomly turns off. We also started to notice a click sound every now and then even when the oven and stove top are turned off and cool to the touch. I ran a self clean cycle with the same behavior, i.e. it got hot then shut down long before it was supposed to. Any ideas?
To be honest, it sounds like you purchased a secondhand, faulty appliance. Although it might be loose connections due to the move, the most likely issue would be the main board and due to the price of them, that is often a good enough reason to buy a new stove.
Error messages are normally searchable, but not that one. Take it back or call out a Whirlpool Service engineer to diagnose, fix and set it up. It is a sorry tale and not an easy one to fix.
No solution, just that you are not alone. We have had our Whirlpool super capacity 465 for 10 years, and about a year ago that large burner started to randomly go to high, even though the control is set to simmer. Ruined a few meals by not being right there watching.
Is the gas turned on to the stove? Is the pilot light lit? Any special circumstances surrounding this incident? like this stove is new or old. Or you are new to gas stoves etc.
In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility Co.works on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
Are you trying to replace the stove top element, or oven element? For the stove top element, just lift up the side opposite where it plugs in and pull straight out.
The oven element usually have one or two screws holding a plate in near where the elements go into the back of the oven. Remove the screws and pull straight out. Reverse the procedure to install a new element. The top broil element will be secured in with a couple brackets to hold it up, these must be unscrewed, removed, and then pull the broil element out.
Remember to turn off power to the range before replacing any of the elements.
try the broiler if it lights then replace the oven ignighter in the bottom under the bottom plate of the oven cavity reply if the broiler doesn't light
